Sponsored By:
Sponsored By:
Spec-D Headlights
Old 07-28-2023, 11:57 PM
Kev.g37s
Kev.g37s's Avatar
Spec-D Headlights
I’m having a problem with my new spec d headlights. When i turn my headlights on (not auto headlights) SOMETIMES both the bulbs turn on. I turn them off the back on, only the left one turns on, turn them off, then back on, only the right one turns on. Anyone know a solution to this? Or why it’s doing this?
Old 07-30-2023, 11:24 PM
SkysG37
SkysG37's Avatar
Are these the headlights that take the stock ballast and bulbs?
I'd start with double checking connections, wires, grounds.
Then, if the problem persists, maybe swap ballats/bulbs side to side. See if the issue swaps as well.
if it's a problem with the built in LEDs, return them as faulty.
good luck!
Old 05-15-2024, 11:39 AM
Caleb J
Caleb J's Avatar
I have a 2014 Infiniti q60, I also bought the same Spec D LED lights, and I’m also having this same issue. Have you been able to find a solution, or at least found the issue?
I have the stock ballast, and the stock bulbs in.
greggv
28
06-26-2022 07:17 AM
Jo3nahxS
10-18-2018 11:10 AM
Idkanymore
01-23-2013 01:59 PM
AndrewDDS
09-24-2008 10:58 PM
Quick Reply: Spec-D Headlights
