Electrical problems help
Old May 3, 2023 | 08:33 PM
Arodbp1002's Avatar
Arodbp1002
Originally Posted by SonicVQ
If the engine RPM is limited to 3500 RPM, that means there is a problem with the VVEL system or VVEL/ECU communications.
(As per the Fail-safe section in the FSM)
Have you measured the voltage of the battery with the car at idle? Typical voltage is high 13 to 14 volts
If it is overcharging, it can only be the alternator.
Yes, i did. So with the big 3 without the original negative cable terminal it was giving me 14.3v (0g pos alternator to battery, 0g chassis to engine, 0g battery terminal to chassis). Then i removed the 0g grounds and replaced them with the ground braided strap and the original battery terminal with the sensor putting out 13.2 to 13.5v.
KevinC5
Sep 19, 2024 10:26 AM
Tompuma28
General Tech Questions
Jun 25, 2022 08:33 PM
MJaga
Apr 16, 2015 12:33 AM
daren_ipl
Dec 3, 2013 09:26 PM
CrackHeadMonsta
Mar 7, 2010 10:40 AM
