2009 Keeps Misfiring
Old Jan 17, 2023 | 11:07 PM
thproblem's Avatar
thproblem
I keep having this issue where my engine keeps blowing coil packs and misfiring. It'll start off really slowly and gradually gets worse until the whole car shakes. I need help finding the source of the issue, I have gone to many mechanics already and they just keep changing coil packs as if its normal instead of getting to the root of the issue. Any one here have any ideas on what it could be. If I cant sort this out I will have to be getting rid of the problem and I really don't want to do that cause I love the car so much!!
2009 INFINITI G37s RWD Auto Coupe | R2C Cold Air Intake | Stock Wheels | Resonated Test Pipes | Muffler Delete
Old Feb 19, 2023 | 09:28 PM
alx.g37's Avatar
alx.g37
Did this start after you installed your test pipes by any chance? I had a similar situation and spent about three months trying to diagnose it and fix it by changing spark plugs, coils, etc. Turns out the car was just running lean from the test pipes and just needed a tune, could be the same issue with you. Assuming you're already tuned, I would check for any exhaust / intake leaks, assuming you've already done all of the common fixes. The Z1 test pipe to header gaskets can leak quite a bit, if you have those. I just used some red RTV and coated the gaskets on both sides and my leak went away.
Best of luck!
Old Feb 21, 2023 | 11:44 AM
thproblem's Avatar
thproblem
Best of luck!
No its been an ongoing issue ever since i got the car. I am planning on tuning it to see if it helps. Thank you for your advice. Would an UpRev tune from Z1 or NisPerformance do the trick you think?
Joshua Milner
Mar 4, 2021 01:46 PM
LPV36
29
Dec 12, 2018 03:01 PM
InitialDeezNutz
General Tech Questions
Feb 19, 2015 11:43 AM
myk1013
Mar 1, 2009 11:50 AM
