Lost Key Fob
Old Dec 13, 2022 | 12:44 PM
HB4LTHR's Avatar
HB4LTHR
Lost Key Fob
I was recently traveling and lost my key fob going through airport security.
In the event the key fob cannot be found does anyone know how to deactivate
it? I don’t feel comfortable with my key fob floating around out there.
Thanks
Old Dec 13, 2022 | 12:49 PM
iCrap's Avatar
iCrap
I could be wrong, but I think the car only allows two fobs programmed. So if you replace it then it should be automatically deactivated.
Old Dec 13, 2022 | 06:56 PM
HB4LTHR's Avatar
HB4LTHR
Thanks. Would the dealer be able to provide a replacement?
Old Dec 14, 2022 | 12:15 PM
ILM-NC G37S's Avatar
ILM-NC G37S
You can have up to four (4) different key fobs registered to your car.
As for a replacement, the stealership can easily replace and reprogram your fobs- but it will cost ($$$$$). For example:
  • actual fob (p/n:285E3-JK65A) ≈$175 (would have to verify against your VIN)
  • actual metal key blank (p/n: H0564-EG010) ≈$15
  • reprogramming/ cutting fee: at least $125 (depends on hourly rate)
The above would the the most costly but least aggravating option.
A cheaper alternative would be to buy a used (or new) fob off eBay and have a QUALIFIED/ licensed/ reputable locksmith reprogram the fobs. The reprogramming will erase all of your current key/fob ID's (including the "lost" fob) and start everything from scratch. If you buy a new fob, the locksmith should also be able to cut the metal portion for the physical door lock. The general consensus is that most reputable locksmiths would charge ≈$100, or less, for that service.
Old Dec 16, 2022 | 11:15 AM
HB4LTHR's Avatar
HB4LTHR
Thanks. I found a local locksmith who can do it for $235 vs the "stealership" at $530.
Old Jan 13, 2023 | 10:54 AM
josephcl's Avatar
josephcl
Unhappy
Was that the price for the fob and the programming service?
My dealer just quoted me $385 for fob and programming and cutting the key.
Old Feb 22, 2023 | 03:28 AM
mummy2's Avatar
mummy2
You way over paid.
Old Feb 22, 2023 | 03:33 AM
mummy2's Avatar
mummy2
You can find new or used fobs, make sure to get oem ones, online for less than $100. If you have a https://www.batteriesplus.com nearby call to see if they do programming at that store. Unless they raised their prices should be around $35 for the programming and $10 for the key cutting.
xxg00w0
Dec 6, 2012 01:49 PM
rks
Jul 5, 2012 09:52 PM
Mantis3024
Jun 11, 2009 04:01 PM
hopgo
Nov 30, 2007 07:28 PM
