Where does this cable plug in? (Passenger airbag notifcation on dash)
*2010 G37 Journey Coupe*
A couple of months ago I swapped my entire dash. Got it back together and everything is working well, but one item was that the airbag light stays on (methods to turn it off don't work).
I noticed that the "Passenger Airbag" notification light doesn't light up anymore if I set something light in the passenger seat... so I disconnected the center console components again and found that the cable leading from the passenger airbag light is still unplugged.
The problem is I don't know where this plugs in. It technically fits the spot behind the clock, but that was connected and working as expected with another cable.
Aha, thank you. The foam was what was hiding it. For future possible readers of this thread, it's in the same wiring harness that is running to the button panel (shown in the pic above), but the female connector is further back on the wire and covered in foam so it's easy to miss.
