14 Q60 p0456
Old Oct 16, 2022 | 08:31 PM
Chipz's Avatar
Chipz
14 Q60 p0456
Having trouble w this p0456 code. Car has a rough idle at times. Any ideas ?
Old Oct 17, 2022 | 09:05 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Download sections EC (Engine Control) and PG (Power & Ground) from here (though I would strongly suggest you take time and download the whole manual.
Section EC will explain how to diagnose your P0456 code. In a nutshell, the ECU is sensing a small leak in the EVAP (emissions) system. In these cases, the gas cap is often the culprit but it can also be traced to a bad vent valve or worn/ damaged hoses.
When you fill your gas tank, do you stop when the pump stops or do you prefer to "top it off?"
If it were me, I would replace the gas cap as that is the easiest and cheapest option to start.
takemorepills
Dec 13, 2018 06:23 PM
Mechdziner714
Oct 30, 2017 07:34 PM
mokotoks
Sep 16, 2014 06:18 PM
eatwiththeking
Video Share
13
Jul 23, 2014 08:20 PM
