Fitment Help
Old Aug 22, 2022 | 02:07 PM
kameronovo's Avatar
kameronovo
Fitment Help
2013 G37x Coupe with 19x11 wheels +7mm offset.
No I did not buy these rims, they came with the car when I bought it. The tires I have are way too small for the rim and the rims are absolutely getting destroyed. The wheel manufacturer recommends at least a 265-275 wide tire and I’m not sure if that’ll fit. If anyone could help me out it would be greatly appreciated, as I’d prefer not to get new rims.
Old Aug 23, 2022 | 11:49 AM
projectpanda13's Avatar
projectpanda13
The wheels are just too agressive for the car. The previous owner stretched the tires to give clearance.
There's no way around fitting these wheel without the poke unless you keep the stretched tire and add negative camber.
The only other option would be to modify the fender or go wide body/flares if you want to mount wider tires on this spec.
g-wagon
Feb 15, 2018 07:59 PM
Sean McLaughlin
Mar 25, 2017 12:38 PM
amorales1729
Jun 3, 2013 12:10 PM
newgman09
Mar 12, 2013 08:09 PM
Brenttheviking
Sep 29, 2012 10:44 PM
