Limp Mode
Old Aug 5, 2022 | 09:08 PM
beefychicken's Avatar
beefychicken
Limp Mode
Not a question, but a resolution that I thought I would put out for future reference.
2014 Q60S AWD.
Problem, Code P0101 -Bank 1 MAF out of range- and limp mode / CEL
Troubleshooting: clean / replace MAF sensor. Would correct issue for a while then come back.
Started monitoring the intake air Cubic Feet Per Minute (CFM) and noticed Bank 1 would slowly creep higher than Bank 2 and MAF voltage would correlate with the CFM split.
Schooled myself on bridge circuits, MAFs, etc. Decided that there must be a voltage problem that could be caused by wiring or connectors.
Verified wiring / connector problem by noticing that repositioning the wire harness would change the CFM on Bank 1. (This is why changing and cleaning the MAF was fixing it for a period of time as it moved the wires when the sensor was removed.)
Dare I say how long this had been going on : (
Solution: Replaced Bank 1 connector with a connector / pigtail from Amazon.
Result: Bank 1 is 100% in range according to the FSM voltage tables.
Bad news: Bank 2 is now higher than Bank 1. So now I will be replacing that connector tomorrow.
Just for those curious, I chose to log CFM as it was much more sensitive to fluctuations and changes. Thus, I could predict the point that it would go into limp mode much more accurately than with just watching the MAF voltage.
Hopefully this helps someone at some point.
Paul_G37
14
Apr 27, 2023 08:16 PM
RaisinBran210
Oct 21, 2020 02:32 PM
timjb24
Aug 18, 2019 03:00 PM
2thdok
Mar 30, 2019 10:49 AM
aznwash3wboi
Apr 3, 2013 12:04 PM
