Which side is bank 2?
Old Nov 26, 2021 | 02:24 PM
FancyZ's Avatar
FancyZ
So my car thru a code 2 days after buying it, turns out it's p0430 cat system bank 2, which side of thr motor would that be?
Old Nov 26, 2021 | 08:37 PM
beefychicken's Avatar
beefychicken
Drivers side
Old Nov 26, 2021 | 09:49 PM
FancyZ's Avatar
FancyZ
Originally Posted by beefychicken
Drivers side
thanks man, funny thing is that cat converter was just replaced a few days ago.. wonder why its throwing a code.. hmmm 🤔
Old Nov 26, 2021 | 10:21 PM
beefychicken
Why was the original cat replaced (same code)? regardless, if the work was done by a shop, you might want to take it back. If you or a friend did the work, then you might want to dive under there and make sure everything is tight and the O2 sensor wires are not pinched or damaged. G-Trivia: the driver's side is the difficult one to work on, not saying the other side is easy, but...
Old Nov 26, 2021 | 10:36 PM
FancyZ's Avatar
FancyZ
It was done professionally at the shop I work at. The guy that did it is going to take a look at it soon. As for why it was replaced.. I'm not sure, it came thru my shop for an inspection before it went to the dealer, where I bought it. My boss said he believes there was a rattle noise coming from the cat, so they replaced it
Old Nov 27, 2021 | 06:37 PM
mummy2's Avatar
mummy2
Did you use some aftermarket cat as a replacement?
Old Nov 27, 2021 | 07:13 PM
FancyZ's Avatar
FancyZ
well it looks like the factory one does, but I'm sure it is aftermarket
Old Nov 27, 2021 | 07:18 PM
mummy2's Avatar
mummy2
I bought a aftermarket one too and I would have the light come on randomly so I would just reset it until the next time. Assuming everything is okay with the install I think it's just a roll of the dice when dealing with aftermarket cats.
Old Jan 22, 2022 | 03:23 PM
FancyZ's Avatar
FancyZ
Update to this... it most definitely is an aftermarket cat, and as of now I just keep clearing the code. Pops up every now and again.
nethole
21
Aug 30, 2023 01:34 PM
Oscar100K_G
Jan 30, 2019 10:34 PM
Glenn2008
Nov 20, 2018 01:21 PM
Glenn2008
General Tech Questions
Aug 6, 2018 02:14 PM
irokdastar383
Aug 2, 2013 04:31 PM
