Need Help - Trunk Crud
Old Apr 30, 2021 | 03:03 PM
cg0837's Avatar
cg0837
Can someone explain/help on why this is here and how to fix this, it’s in the trunk and after a wash I opened the trunk and found that, there was more build up of soap foam
Old Apr 30, 2021 | 03:50 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Perfectly normal. The crud is debris that falls down the rear windshield and into the drainage "channel" of the trunk. As water drains, it carries the debris along the drain path where it accumulates under that plastic trim piece. Just clear the crud away and water will drain better under that plastic trim piece (see pic). Otherwise, you have nothing to worry about.
Old May 3, 2021 | 01:00 PM
jpowersjr2's Avatar
jpowersjr2
I just cleaned my buddies G out. His was clogged so bad that water would collect and not drain. Pressure washer FTW. The plastic panels can simply be pulled/popped off.
Old May 3, 2021 | 01:34 PM
ILM-NC G37S
I thought I read somewhere- here on the forum, perhaps- that someone had trimmed the bottom lip of the drip channel trim panels to allow for better drainage?
This larger opening would help to prevent the "damming" effect.
Edit: found that thread here.
I just pop the trim pieces off, clear the crud, and pop back on.
tite_tite
General Tech Questions
37
Feb 23, 2024 06:34 AM
Topher9425
Jul 17, 2015 02:14 PM
dkmesa350z
Sep 16, 2014 11:28 AM
Infiniti7
Mar 11, 2012 11:40 AM
SindhiStyle
Nov 1, 2009 06:02 PM
