New wheels and car is shaking
Old Feb 23, 2021 | 05:14 AM
munzer's Avatar
munzer
Hello everyone,
I bought chinese wheels on my car and after using them for about a month, the car is shaking on low speeds (80km/h). I went to a shop and he told me that there is like a space between the original rim space and the rim itself. What should I do in this case? Can I fix the problem without changing the rims?
Thank you
Old Feb 23, 2021 | 08:33 AM
Bravo at's Avatar
Bravo at
Sounds like Hub Rings. If it is, then go with steel or aluminum, plastic can dry rot/get brittle over time.
Old Mar 2, 2021 | 04:28 PM
Isxlow's Avatar
Isxlow
Could also be a warped/bent rim since you bought cheap chinese wheels
Old Mar 3, 2021 | 08:28 AM
RMB5190's Avatar
RMB5190
This would be my first solution based on what mechanic is telling you. Need to know ID of new rim hubs and get rings with w/ an outer ID that matches them and an ID of 66.1mm.
Example: https://www.ebay.com/itm/SET-OF-4-HU...72.m2749.l2649
ak1
Jun 20, 2017 12:32 PM
willd828
Dec 29, 2015 11:58 AM
SiKHG37
Nov 30, 2015 09:27 PM
knothx
May 15, 2012 12:07 PM
Skilled
May 14, 2012 06:21 AM
