What is this loose wire?
Old Jan 22, 2021 | 10:07 AM
G37EO's Avatar
G37EO
Guys I found a loose wire in my newly purchased G37s coupe 2008
not sure what I that.
also I found a refrigerator thermostat that is bent over the cooing line and also loose
what is that loose wire and why do you think there is a loose thermostat on that cooling line?
Old Jan 22, 2021 | 12:34 PM
BULL's Avatar
BULL
Moderador
The only thing I can think off is their compressor was not working and they wanted to have it turn on and off by itself without it freezing. You see that thermostat cuts signal once it gets to a freezing point, so possibly connected the thermostat in between the compressor and sent power to it. If they line freezes the Tstat would cut the signal.
Not a bad way to rig it however I question the efficacy of it being that that line varying in temp since it's so close to the exhaust. That Tstat moved up by the brake reservoir would have worked better.
If your compressor is working along with everything else, remove it.
Fishermr
Nov 4, 2016 02:01 PM
cmjman
Mar 22, 2008 05:08 PM
ABQG35c
Buying & Leasing
Oct 5, 2007 06:44 PM
