Hub rings?
Hub rings?
hey, I have aftermarket wheels that came with the car when I bought it and have no way to find the model of the wheels, the wheels are lug centric and dont have a spot for a hub ring inside that discount tire could find, would a hub centric spacer help my issue? My issue is the vibration with the wheel moving around because it's lug centric, thanks
Lug Centric typically means the bore diameter is larger so the wheels can fit a wider array of vehicles. Post a pic of the wheels and we can try to figure out what kind they are and go from there.
Chances are, you will need a ring that takes the aftermarket wheel hub to a 66.1 ID
Can'tGme
Jul 27, 2013 09:40 AM
TJHG37S
Southern California
16
Jun 10, 2009 10:43 AM
