370z Nismo rims on G37 coupe will it fit?
Hi all,
I just picked up a set of 370z Nismo rims for my G37 coupe.
Front 19x9 +40 Rear 19x10.5 +23
I have tires from my stock rims that are 245/40 (front) 275/35 (rear)
I wanted to know if this size tire will work on these rims or if there is a better size recommended that I can use to fit these on my car. I know the offset is quite aggressive for the G37 so stretching will have to be done. I am also lowered on BC coils.
I would appreciate the help! Thanks!
Hi all,
Hi all,
I'm running 245/40 on 9.5" and 275/35 on 10.5". My front tires are a little bit on the stretched end and since you're on a 9", you'll be fine. Rear tires have little to no stretch
Your rears fitment will poke out a bit and the fronts will be a little bit sunken in from fender
Those tire sizes fit no problem.
