Performance Increase
Old Feb 29, 2020 | 01:07 AM
takemorepills's Avatar
takemorepills
Originally Posted by Invaderzim
A fella on facebook has swapped a used trans from a Q60 red sport into his G. The two cars share the same 7AT with the exception being the internals are upgraded to handle the higher torque from the twin turbos. He had to shorten his drive shaft because the RS trans has a longer bell housing for the beefier torque converter. (triple disc!) He also swapped the TCM and had to drill a hole for the crank sensor as well as using the trans mount from the RS. This looks to be the cheapest route to getting an upgraded 7AT that can handle over 400 ft. lbs of torque.
I also wonder if the Titan 7AT can be utilized.
Old Feb 29, 2020 | 12:42 PM
Invaderzim's Avatar
Invaderzim
I have not looked into that one. The facebook guy chose the Red Sport because he has the GTR twin turbo conversion kit on his G. Makes sense I guess. Last update he was looking into see if the RS drive shaft would be a direct fit also. That would make the swap a virtual bolt in upgrade. We can dream can't we? I've always wanted to do FI but the cost has been just too high for me to justify. Being able to knock several thousand dollars off?..Tempting more than ever.
Old Feb 29, 2020 | 08:39 PM
takemorepills
Nissan changes things so little I wouldn't be surprised if the RS ds would be a direct fit. One way to check would be compare wheelbase of G37c to Gen2 Q60, if they are the same, they likely utilize many things the same.
BTW, I just checked, both are 112.2".
They are essentially the same car.
Years ago I bought a 2004 I35 that was wrecked at 5K miles, and put EVERY DARN PART into a 1997 FWD Maxima. The seats, harness, engine, everything bolted right in. Only difference between the 2 cars? One was an early gen OBD2 and the Infiniti was advanced OBD2 with NATS.
Even the back seats fit perfectly into the older car.
Nissan doesn't change a thing.
Even the new Titan (non-XD) is just a re-skinned Gen1 Titan.
Old Dec 23, 2020 | 09:40 PM
InfiniteStuff's Avatar
InfiniteStuff
Just stay away from these 'performance chips' which add nothing except bills to your wallet
https://www.performancechipguide.com...view-teardown/
Old Dec 24, 2020 | 04:08 PM
sobeIPL's Avatar
sobeIPL
Nope. Just accept that whatever you do will probably destroy the leather wrap on the OEM ****. I'm not saying it can't be done, but it's uncommon. Good luck.
BTW, what you did here is called thread-jacking.
What am I missing here? OP (or hijacker) is just trying to change their shift ****? Why is this an issue? I changed mine just fine.
Old Dec 24, 2020 | 04:27 PM
OP wasn't asking about **** removal.
You got lucky yours came off without a fight, that's all.
Old Feb 25, 2021 | 10:25 PM
Deannie's Avatar
Deannie
Originally Posted by vros_q60s
Hello guys, so I have a ‘14 Q60s coupe/g37 and looking to increase horsepower and torque. I have twin cold air intakes installed but don’t know what else can be done to give a significant boost. I’m not looking for a turbo kit btw as they’re really expensive for these cars. Thanks!
Someone earlier said intake, exhaust & tune. Bear in mid that if your CAI draws air from under the hood (on either side of the engine) you’re drawing warm engine-heated air which won’t boost hp no matter how nice they look. If your CAI draws air from in front of the radiator or elsewhere outside the engine compartment, then that will serve well but make sure you have some sort of rain/splash shield. As for tune there are good options available if searched on this site. As for exhaust, make it at least a cat-back exhaust (axle-back won’t do much for hp) with 2.5” diameter pipes (bigger than that won’t necessarily add hp). Milder suspension mods work wonders for handling. Eibach sway bars front and rear with NEW links have been great for me but other brands will do - just don’t go for the cheapest options as they may be worse than OEM). I advise against substantially lowering the car because it’s already got a low, aggressive stance and life is full of speed bumps, potholes and curbs (don’t wanna back up into a curb with your new exhaust tips taking a hit) and I’ve seen too many “slammed” G’s and 370Z’s with fender rubbed tires and damaged front air dams - what’s the point? Perhaps the best way to improve performance and even improve braking would be to buy lighter wheels (same size as stock) if they’re available. Remember, “adding lightness” is the same as adding horsepower - who wouldn’t want that?
Autmnkestrel
Feb 25, 2019 02:53 AM
uzbekuz
Mar 14, 2016 04:36 PM
saeed24111
Jun 6, 2011 06:53 PM
fcarpio
Jul 25, 2008 02:20 PM
bloodhound
Jun 28, 2007 01:05 PM
