Help-Soft Slapping/Flapping Noise?
Hey Guys,
The past few days I've heard a soft 'slapping' or 'flapping' noise coming from the drivers side wheel area while going anywhere from 5mph- 40mph with windows down. I disregarded it at first but the noise is not getting any better or worse. It can almost be comparable to as if you were slapping a post-it (or a strip of paper) on the edge of a table. Any thoughts on what this can be?
Recently installed Michelin PSS & Hotchkis sway bar. Not sure if this is a factor or not.
Would be thankful for any responses or experiences. Thanks!
Cell
Cell
I wish there was a fish so I knew what the problem was . Something I forgot to mention is that the 'slapping' noise increases as the speed increases. And I did not scrape over anything recently.
guy from norcal (05-04-2017)
I had that same flapping noise when I scrapped harshly one time and it was annoying for a whole day. Turned out a to be a thin metal flap right under the middle of the car-ish would sit, snapped it back into place. Problem solved.
cellwoot (05-05-2017)
I have a very similar/same sound that's been driving me nuts. What's worse is it sounds almost like a lightly spun or rattling rod bearing but I have tried to replicate the sound at a stop or while under the car and I haven't heard it even once. I have tried checking the fender liners and any and all plastics. In fact, I just removed almost all of them to see if it would fix it and it hasn't, still flapping or rattling while driving. Let me know what you find..
Two weeks later, still cannot find a thing. Since the rate of the noise increased/decreased as my speed increased/decreased, I had thought it might of been a nail or something that I missed. No nail.
Splash guards in place, fender liners are secure.
Doesn't happen when I'm turning, reversing, or going under 5mph.
Besides the fact that it's super annoying with summer around the corner and windows down, it does not affect driving with windows up. -Knock on wood-
I'll be taking it to see my local mechanic in 2 weeks. Hopefully he'll find the problem if I haven't already in the time being. I'll keep you guys updated.
Weird man. I have a similar sound too but its only while first taking off and after about 10 mph it goes away. If its louder as you go faster, it's gotta be something rotating or something flapping in the wind. Have you checked your weird little mud flaps in front of the rear wheels that hang down? That could be hitting the underside.
Update:
Two months has passed since 'flapping-noise'. The noise disappeared on its own without having to take the vehicle into a shop. No nails, no loose materials, nothing out of the ordinary. Weird.
Over the course of the two months, I drove the G normally with a few spirited drives here and there. Will the noise come back? I don't know. Only time will tell.
