Battery drain
Old Jun 20, 2017 | 06:28 AM
ezbme's Avatar
ezbme
I believe the caps on the new battery can be popped off. Most are considered maintenance free. To confirm, you want me to open it and fill it more?
Old Jun 21, 2017 | 05:07 AM
Surfnazi's Avatar
Surfnazi
Yes you fill the chambers to the top
Old Jun 21, 2017 | 05:17 AM
telcoman's Avatar
telcoman
Not to the top
Fill to the fill ring below the top after you remove the caps using distilled water
Use a flashlight to see it
Telcoman
Old Jun 21, 2017 | 12:39 PM
Surfnazi's Avatar
Surfnazi
Just make sure it's not low
Old Jun 21, 2017 | 01:07 PM
mummy2's Avatar
mummy2
Originally Posted by ezbme
My car didn't start on the 11th. I took a battery charger and got it to start. I had AAA come over and check it. They said everything was fine, but the battery was showing around 435 CCA might have been CA. They suggested I get the battery replaced in the next six months.
I am getting a new battery tomorrow. It is a Bosch from Pepboys, it is $104, has a 96 month Pro Rate with 3 year free replacement and 640 cca
Anyone have any thoughts, I saw something about the Bose amp causing a drain.
Sears and Kmart DieHard Gold 50823 (north) and the DieHard Gold 50923 (south) are the 2 highest rated batteries for our car according to consumer reports. Just picked up the 50823 for $95 after tax at Sears. Paid online, to get the online discounts, for instore pickup. These are 24F
Old Jun 23, 2017 | 10:10 PM
ezbme's Avatar
ezbme
I got a battery, it is a bosch 35, but I have already had a problem. I am hoping I accidentally left it on ACC again. When I parked, I realized I hadn't turned off the radio, which I heard could be a cause of the drain. So I turned it off and then as far as I know turned off the car.
Today I get off work early and the car won't start. Someone at work jumped it. The first time I tried to start it, it cranked and didn't start. Same with the second, the third time it started. The battery was really dead though. The two times it hasn't started at work I had it sitting all day and it was pretty hot out.
When this has happened, I have pressed the brake pedal and it stayed down like someone was still pressing it. It feels like something electrical and not necessarily the battery, I just spent 114 for a new battery. When I hooked up my co-workers car for a jump, it took a few minutes to start. It cranked two times before starting. I took the car to the place I bought the battery to get it tested, it tested fine. Started fine as well. I changed to my spare fob to see if that helps. I have only had the car 8 months. I am so frustrated. I have a G37S Sedan with Automatic.
To add, not too long ago, I found a plastic nut on the floor and didn't know where it came from. I will look around, perhaps it is near the brake pedal. I kept the nut in the car and thought to myself, "hopefully this doesn't cause a problem.
Old Jun 25, 2017 | 12:51 AM
saywat?'s Avatar
saywat?
Could be from floor carpet fastener. There's one by fuse cover by pedals.
Old Jun 25, 2017 | 01:09 AM
mummy2's Avatar
mummy2
Yea, thats just the little nut that helps keeps the carpet and/or fuse cover in place.
Old Jan 19, 2021 | 09:47 AM
akeyes01's Avatar
akeyes01
2008 Infiniti G37 Parasitic Drain
Hello!
I’ve tried the suggestion of trying to find the part/device that is draining my battery by going through the steps I’ve found online. The problem is when I hook my multimeter up to my battery post and terminal the car horn keeps beeping off & on and the reading on the meter fluctuates wildly up and down so I can’t get an accurate sense of what the amp drainage is.
Does anyone have an idea of what I’m doing wrong? Thanks!
Old Jan 19, 2021 | 10:56 AM
BULL's Avatar
BULL
Moderador
Originally Posted by akeyes01
Hello!
Your car is tripping the alarm, while this is happening, Unlock the vehicle with the fob and it will turn it off.
clouser
Jul 4, 2022 01:48 PM
Kampuchea_G
General Tech Questions
Jul 31, 2017 06:04 AM
ufo
Aug 22, 2014 11:27 AM
inyquest
Aug 1, 2013 12:13 AM
C@ciQ
33
Mar 21, 2009 03:56 PM
