G37S 6MT Questions
G37S 6MT Questions
I have been having a few problems with driving my G37 since the purchase, this isn't my learning to drive manual transmission car, but i have noticed that the clutch is pretty tricky to learn. Basically one of my questions is 1) how do you guys adjust your seating position correctly to drive ? I find that my position hass A LOT to do with how i drive, but i can't seem to find the perfect position. Also when shifting from 1-2, any tips to have a smoother shift ? Thanks !
Hey myblackg37 - welcome to the site
I find seat positioning critical when driving a MT. Having the seat too far will cause me shifting issues specially from 1-2
In case you have not seen this...a couple of options for the pedal:
Clutch Pedal Assist Spring for 6MT
RJM Performance Clutch Pedal Assembly
g/l
g/l
g/l
g/l
When I adjust my seat, I make sure that I can fully depress the clutch while still having a slight bend in my knee. Shifting from 1-2 smoothly is something that you will get better at over time in my experience. I typically let the clutch out to the biting point before fully release the clutch to make it smoother.
I actually like the clutch in this car. It seems that many people do not like it. Maybe it's because I learned on this car so I got used to it.
Slateblue is on to it. Shift slower, let rpms drop first. As the last of the engagement occurs, be more agressive of the throttle and then dump the last of the clutch. I've been driving manuals for fourty years. I think the electric throttle pedel is what makes it challenging. There is a bit of a delay in it. Have to press it agressively
I try to position my seat closer to the wheel so that when the clutch pedal hits the floor/firewall, my leg isn't completely extended. You have much more control over your leg when lifting off because your knee is closer to a 90 degree angle than if you tried overextending your reach at the bottom.
I find that there's 3 ways of shifting smoother from 1 to 2:
1. Short shifting at 1.5k-2k
2. Shifting above 3k
3. On harder launches, drop the pedal to the bite point right after shifting, keep it there until you catch (this will inevitably cause much more wear)
OP, I have the spring I purchased from Jsolo, I no longer use it because I have the RJM pedal kit installed.
If you pm me your address I'll send it to you at no cost.
Jsolo helper spring was a great mod. You say you like the clutch stiffness, but that is what makes the engagement between 1-2 so bad.
We all know the engagement point is very small, that powerful OEM spring does not allow you to control as good as a softer spring. I would highly suggest giving that a try because it is a cheap fix.
I am 6'4", and have to move the seat up maybe 2 inches to properly engage the clutch. As previously stated, the clutch should be to the floor, and a bent knee will help with that.
I'll second that opinion. It's a relatively easy DIY, costs virtually nothing, and will have a very positive impact on the drive-ability of this car. I had jsolo's spring for 3 years before finally swapping in the RJM clutch pedal assembly, and while the RJM is worth every penny, the spring is a fine little mod.
OP, Gio37 is offering you his old spring for free. Jump on that.
Not sure where mine is. Probably on the OEM assembly, in the attic somewhere.
Another one vouching for rjm. My only complaint, stop making so many damn revisions! My V3 now feels obsolete, what with the v4 that doesn't require adjusting the clutch switches, when you adjust the pedal.
But seriously a great product.
Wait...there's a version 4? I thought the latest was Rev 3.1.
Just drive the car more. It gets so much easier to shift once you are in tune with the car. I did not buy a new pedal or anything...I just kept driving. One thing that helped was low speed driving. Taking off and driving in parking lots and what not at like 2-5mph. It helped me learn the stall threshold of the car without being in traffic (in case I stalled out). But you can feel how the clutch bites and where so when you are out driving for real, its not a mystery and its not weird.
