Is this a bad leak?
Old Mar 9, 2017 | 12:35 AM
taimysho0's Avatar
taimysho0
Is this a bad leak?
Just noticed a leak under the car, seems to be coming from this big bolt. Any idea how much it cost and what this is from? Looks like rack & pinion.
Old Mar 9, 2017 | 01:25 AM
crookncastle's Avatar
crookncastle
thats the tension adjustment for steering returnability and stiffness for the rack and pinion. i don't believe it can be bought separately. i have seen seepage from the adjustment on my other nissan vehicle too, but i have never had it leak to the point where it drips onto the floor.
Old Mar 9, 2017 | 02:35 PM
Kris9884's Avatar
Kris9884
Yeah, definitely your steering rack. Not sure what the bolt adjusts but I would manually tighten it, I can only assume it came loose.
Old Mar 9, 2017 | 04:35 PM
Glenn2008's Avatar
Glenn2008
On the Z forums I found someone who had the same issue. He said not to tighten the bolt, but to clean it off really good and use some shoe goo. He claims that he did it and 8 months later still no additional leaks. Yours may be leaking too badly, but it may be worth a shot.
Old Mar 9, 2017 | 05:57 PM
Glenn2008's Avatar
Glenn2008
Permatex may be a better solution.
Old Mar 9, 2017 | 06:22 PM
Glenn2008's Avatar
Glenn2008
Permatex 82099 - Spray Sealant Leak Repair | O'Reilly Auto Parts
Old Mar 10, 2017 | 02:35 AM
crookncastle
do not listen to the person stating to tighten that bolt. you will affect your steering returnability and steering wheel tension when you tighten it. clean it off real good with brake cleaner. check it during your next oil change and see how bad it seeps out. to me its just normal seepage but because it has accumulated over time it looks worse than what it its.
Old Mar 10, 2017 | 02:48 PM
Kris9884's Avatar
Kris9884
F me right? Lol that dude's right, I had no idea Nissan would leave a vital adjustment bolt out in the open like that.. But, in other cars, you're supposed to loosen the lock nut, tighten the adjusting nut all the way, then back it out about a 1/4 inch and lock it down again. It should feel like a new steering rack to you if you've gotten use to it being leaky and loose..
Old Mar 10, 2017 | 02:55 PM
Kris9884's Avatar
Kris9884
********** 1/4 TURN **^^^^^^^ Not inch lol
Old Mar 14, 2017 | 12:57 PM
Glenn2008's Avatar
Glenn2008
So did you try the Permatex? Or, have you been able to solve the problem?
Old Mar 14, 2017 | 01:32 PM
taimysho0's Avatar
taimysho0
it looks like it was my mistake, i just bought the car and the cardboard i had used to put under the car had oil stains from the previous car i owned. i flipped over the cardboard and am no longer seeing any stains..thanks for every1s suggestions!
Old Mar 15, 2017 | 03:34 PM
xmajd92's Avatar
xmajd92
Now that's funny
