HELP - Car idles/start and dies.
Old Aug 13, 2016 | 05:56 PM
G37Kev's Avatar
G37Kev
Hello guys.
So my car would just sputter and die when im at a light or at a full stop. I would turn it on again and it would just die again so i would sometimes have to hold on to my gas pedal for my car to stay alive. Then sometimes when im on the highway going 70mph the car starts to struggle like the acceleration wants to cut off so it would shake my car but it doesnt die. I have a 09 G37S Coupe 6MT, my check engine light does not come on and i have 81k miles
So far this is what I've done
-Clean intake filters and pipes (Stillen Gen3)
-Changed to new MAF Sensor
-Cleaned TB
-Seafoamed (oil,brake booster, gas tank) Now waiting on oil change after 100miles
-Changed sparks and coil packs
After doing those procedures my car would still die on me.
Anyone else know whats the possible issue?
Old Aug 13, 2016 | 07:58 PM
Ricio1991's Avatar
Ricio1991
Check the voltage on the battery and go from there. Mine started doing that little by little until it died on me and went on limo mode on me
Old Aug 13, 2016 | 09:44 PM
G37Kev's Avatar
G37Kev
i got the battery replace with an OEM one 4 months ago.
BUMP anyone else?
Old Aug 14, 2016 | 08:34 AM
micafd3s's Avatar
micafd3s
possible fuel delivery.. check your fuel pump
Old Aug 14, 2016 | 05:28 PM
Victory's Avatar
Victory
After cleaning rhe various intakeparts, did you do a pedal position, throttle position and idle air volume relearn?
Have you checked for vacuum leaks?
Old Aug 17, 2016 | 05:47 AM
Surfnazi's Avatar
Surfnazi
Fuel pump might not be seeing right pressure
Old Aug 24, 2016 | 03:05 AM
crookncastle's Avatar
crookncastle
ck fuel pressure. ck for vacuum leaks.
Old Aug 24, 2016 | 11:42 PM
cruzmisl's Avatar
cruzmisl
Originally Posted by G37Kev
Hello guys.
-Cleaned TB
On the nicoclub forum in the g35/37 sub forum there is a thread on the first page of two guys going through the same thing on their 07 G35. They don't have a solution yet but it might be helpful to get on the same page with them if someone finds the solution.
Old Aug 25, 2016 | 09:17 AM
cruzmisl's Avatar
cruzmisl
Possible to double check for vacuum leak?
Engine stalls on deceleration ?!?! Anyone else had this problem ? - G35Driver
Look at post #9 and below
Old Aug 25, 2016 | 10:24 AM
VenomGT9's Avatar
VenomGT9
ECU and throttle relearn
Then move on to the fuel components
Willyr33
ECU Tuning / Dyno Data
Aug 24, 2016 03:46 PM
armino41
Mar 30, 2016 01:25 PM
bonstubon
Mar 18, 2016 04:29 PM
