10mm Bolt Replacement?
Old Jul 30, 2016 | 11:36 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Raise the front of the car then remove the under cover. You'll see if anything is damaged or dented. There's about 14 or 18 of those 10mm bolts + 3 center plastic rivets that hold the thing in place.
Old Jul 31, 2016 | 11:06 AM
The parts that are most prone to that kind of damage would be the engine cradle and the Y-pipe, both are easy to inspect, and like mentioned, going that slow probably just a scrape. The fluid pans are quite a bit higher than those parts so more than likely that's what it was.
Old Aug 1, 2016 | 06:21 PM
G37xS-Life's Avatar
G37xS-Life
Thanks everyone.
I finally got home and the first thing I did was jack up the car and inspect the underside. I found two 10mm bolts missing (one at front and one at back) and I am guessing this was due to tech at dealer being lazy. I don't see any plastic tearing and do not see any impact points any where.
Like a few of you have said, at such slow speed, there was probably no damage.
Thank you all once again!
Old Aug 2, 2016 | 09:58 AM
SonicVQ's Avatar
SonicVQ
Originally Posted by Jsolo
The bolts are metric. Take an old one with you to compare. Stainless steel would be preferred as it's a pretty harsh environment under there.
^^^stainless steel = good, but also = $$$
I always add anti-seize paste to those (easy to rust in place & snap off) 10mm bolts. You can always get them at the dealer, I think they are
Old Aug 3, 2016 | 09:04 PM
saywat?'s Avatar
saywat?
i bought a pack of 20 on ebay from this seller for $10 works great. check to make sure the "u nut?" it screws into is still other otherwise u need that too
Body Bolts for Nissan Qty 20 M6 1 0 x 25mm 10mm Hex 17mm Loose Washer 161 | eBay
Old Aug 4, 2016 | 07:52 PM
G37xS-Life's Avatar
G37xS-Life
Oh great! Thank you!
Old Aug 5, 2016 | 10:21 AM
Kris9884's Avatar
Kris9884
Just fixed mine, went to Autozone and found some fat black round push tabs and filled all the holes with them. There's a joke in there somewhere.
Old Aug 5, 2016 | 07:08 PM
G37xS-Life's Avatar
G37xS-Life
LOL
Old May 18, 2018 | 03:18 PM
presidentsdad's Avatar
presidentsdad
Does anyone know if there is a real difference between the screw/bolt that is simply a hex head vs the ones that have a hex head with phillips head too?
Old May 22, 2018 | 01:56 PM
Surfnazi's Avatar
Surfnazi
No difference
BooPoo
Apr 6, 2016 12:23 AM
