G37S Coupe Exhaust Question
Old Jul 28, 2016 | 02:22 PM
haydendvs's Avatar
haydendvs
Hey guys. I recently purchased an '09 G37S Coupe (6MT) and have totally fallen in love with the car. I've done Eibach Pro Kit Springs and Tanabe Axleback so far. I recently purchased the Berk HFC and the ISR Y-pipe because I am hoping to continue building out the exhaust. I didnt buy the Tanabe Y-pipe because $500 is way too expensive for a simple y-pipe. Just wondering if anyone has experience with the Berk HFC/ISR/Tanabe combination, and if anyone has suggestions for future exhaust work/mods.
Thanks!
Old Jul 28, 2016 | 03:09 PM
Kris9884's Avatar
Kris9884
I have the Tanabe axle back, a Top Speed y-pipe (identical to ISR) and resonated test pipes not installed yet. Did you get resonated HFC? If not, its gonna be quite raspy... With just the axle back and y-pipe the exhaust sounds amazing, I really love it. My build thread has sound clips if you want to check them out. With high flow cats it'll just sound the same but throatier.
Old Jul 28, 2016 | 04:14 PM
AKS14's Avatar
AKS14
TopSpeed and ISR Y pipes are not the same, ISR has a formed merge, Topspeed looks like they just jammed the pipes up and welded them.
Topspeed:
ISR
That being said, they should flow roughly the same.
I run an ISR Y pipe on my car (stock cats, stock exhaust) and its very slightly louder but not really noticeable after you drive for a few days.
If you went with a high flow cat and the ISR Y Pipe the Tanabe would probably sound pretty good and not terribly raspy since you still have a cat. I tried the resonated test pipes out from ISR and they were pretty cool and the car felt more responsive/faster but they were a little loud for my liking so I will be going to a high flow cat to keep the car a little quieter.
Old Jul 28, 2016 | 04:38 PM
Kris9884's Avatar
Kris9884
Ah, I googled ISR because I never heard of them and must have been shown a Top Speed version lol, my bad.. BUT tomayto/tomawto, I could argue that the ISR has only two, more drastic angles instead of the Top Speeds four, less angled curves. Not to mention the Top Speed merges together in a larger area compared to the ISR, which is easily seen in your pictures, its a wash.. Like you said though, I'll bet money they flow within 2-3 CFM of each other in the exact same settings.
Old Jul 28, 2016 | 06:24 PM
AKS14's Avatar
AKS14
I like the merge on the ISR a bit more, internally its pretty large/smooth, compared to the other where it looks like they took the pair of 2.5" pipes and just smashed them into a 3" pipe, the merge on the top speed looks kind of crowded IMO.
Internally the ISR is really big.
I also dig the little dimple brace with the angle at the front, sort of acts as a skid plate so you avoid snagging on speed bumps and what not, instead it just skips over without really grabbing at the Y pipe
Old Jul 28, 2016 | 06:28 PM
Kris9884's Avatar
Kris9884
Ohhhh that IS sick, I didn't see that before, yeah ISR is def superior..
Moe_G37x
Apr 14, 2016 01:52 AM
Saltman
Mar 30, 2016 04:07 PM
Trolololol
Mar 29, 2016 03:09 PM
