Steering wheel removal.. stripped torx t-30 bolt
Old Jun 5, 2016 | 10:19 PM
rolltidealumni's Avatar
rolltidealumni
Thumbs down Steering wheel removal.. stripped torx t-30 bolt
Trying to remove the steering wheel so that I can install a custom-made carbon fiber trim piece. One bolt is standing in my way.... so I tried drilling into it to use an extractor.
But I can't get a hole started. Am I using the wrong drill bit? It's a 5/32" BRITE- Tungsten High Speed Steel 135 Quick Cut Point for "Wood, Soft Metal, Plastic, Plaster."
Or could I get a larger extractor bit to see if I can pull it out with the shallow hole that's there now?
Attached Thumbnails Steering wheel removal.. stripped torx t-30 bolt-img_8846.jpg
Old Jun 5, 2016 | 10:37 PM
hurleyguys's Avatar
hurleyguys
can you file a groove across the top of the head and use a flat headed screw driver to get it out?
Old Jun 5, 2016 | 11:29 PM
rolltidealumni
It's too big for a flat head I think. Also it would be hard to file with it being inside the steering wheel casing.
Old Jun 5, 2016 | 11:34 PM
waitwhat's Avatar
waitwhat
I had the same exact problem as you. I ended up using a bolt extractor kit from Harbor Freight. Use an extension and hammer it in to get more grip. Worked like a charm for me. Make sure you get the SAE, not metric. I think I used the 5/16 in. socket.
9 Piece 3/8" Drive SAE Bolt Extractor Sockets
Old Jun 5, 2016 | 11:40 PM
rolltidealumni
Awesome, thanks for the recommendation. Did you purchase online or in a store?
Old Jun 6, 2016 | 12:13 AM
waitwhat's Avatar
waitwhat
I bought it in store. You can also buy those torx bolts at your local dealer. They're about $0.80 cents or so.
Old Jun 6, 2016 | 09:24 AM
rolltidealumni
Where did you buy the extractor sockets? Already bought new torx bolts from the dealer!
Old Jun 6, 2016 | 12:45 PM
bikezilla's Avatar
bikezilla
This kit works a treat.
One side is a cutter, the other is the extractor. The cutter digs quickly and you don't have to go very deep for it to be effective.
$15 bucks at HD
Speed Out
Old Jun 6, 2016 | 02:10 PM
waitwhat's Avatar
waitwhat
You can find that set at Harbor Freight.
Old Jun 6, 2016 | 02:12 PM
rolltidealumni
I assumed Harbor Freight was an online business.. I've never heard of them. Thanks!
Old Jun 6, 2016 | 02:49 PM
Autocutter's Avatar
Autocutter
This is going to be a real bit@h to get out if the torx gave up-kinda hard to see a double bit extrator would work as the metal must be soft for the torx to fail. There's no shoulder for a rounded nut extrator to grap. I wonder if a soaking it with PB Blaster first would help. I think you'll have the cut a slot for a flat tip.
Old Jun 7, 2016 | 10:09 AM
rolltidealumni
Ended up being able to drill a hole into the bolt and use an extractor to pull it out! Whole job took 2+ hours... but it's finally done. I've had this CF trim sitting in my closet for 6 months.
Think it looks nice
Credit - Carbon Fiber Element for the trim!
Old Jun 7, 2016 | 10:28 AM
bikezilla's Avatar
bikezilla
NICE!!! I like the CF trim.
Where did you get it?
Old Jun 7, 2016 | 10:29 AM
bikezilla's Avatar
bikezilla
You'd be surprised. I extracted a more than one heavily threadlocked T40s with and without the bolt head.
Glad to see the OP got it sorted though.
Old Jun 7, 2016 | 10:43 AM
Ryne's Avatar
Ryne
The Steering Wheel Guy
Looks nice! Now all you need is the steering wheel I'm selling to really pull it all together!
OfficialG
Jun 26, 2016 11:07 PM
-SnowMan-
Jun 9, 2016 04:28 PM
CMBurns
Apr 18, 2016 01:07 PM
VQpoppa
Apr 10, 2016 06:30 PM
Mar 27, 2016 03:54 PM
