Exhaust help
Old May 19, 2016 | 05:51 PM
MarcBIueG37s's Avatar
MarcBIueG37s
Exhaust help
I have a 2012 G37s with a muffler delete and love the sound. But i recently came across an ipl y and mid pipes. Do you guys think if i put it onto my car with the muffler delete will it get louder?
Old May 19, 2016 | 06:18 PM
evil-G-nius's Avatar
evil-G-nius
Probably. I am pretty sure the IPL pipes are a larger diameter than the S. Larger pipes = more exhaust exiting = louder (with respect to no muffler of course) You could get larger pipes and find a way to quiet it down but I guess that would defeat the purpose
Old May 19, 2016 | 06:29 PM
MarcBIueG37s
That make sense. And also do you think it wil be a problem to fit the ipl y and mid with the pipes i put in place of my muffler? Since you said they are a different size.
Old May 19, 2016 | 06:31 PM
PNW_IPL's Avatar
PNW_IPL
Louder? No.
Same size diameter piping.
The only difference is the ipl has an H pipe not a Y. And the muffler is different.
If you make the switch youll gain horsepower due to the true dual design. I doubt itll be louder though. I belive the IPL is quiter than the S due to muffler design. Sice you have muffler delete your only benefit will be power from the true dual.
Old May 19, 2016 | 07:13 PM
MarcBIueG37s
Oh ok, thanks for clearing that up. But i wont benefit from power unless i tune it, correct?
Old May 19, 2016 | 11:41 PM
PNW_IPL's Avatar
PNW_IPL
Who know. The best mod is a tune. Second is hfc or test pipes and cold air intake and then exhaust. By power were talking 5hp ish not much.
Old May 20, 2016 | 10:59 AM
Kris9884's Avatar
Kris9884
Meh, you might get a couple ponies, nothing really noticeable. Are you looking for power or sound more?
Old May 20, 2016 | 01:25 PM
MarcBIueG37s
Mainly sound which is why i did muffler delete in the first place. But since i came across an ipl for cheap i was wondering if it would enhance the sound even more when paired with the muffler delete.
Old May 20, 2016 | 02:51 PM
Kris9884's Avatar
Kris9884
With just solely looking for sound, I'd skip the marginal, if at all, sound difference on the IPL swap and just grab a Top Speed Y-pipe. It'll add quite a bit more sound and maybe even free up 1-2HP. Completely bolt on and cheap.
Old May 20, 2016 | 02:58 PM
MarcBIueG37s
Sounds good, thanks for the help.
rsingerG37
Aug 15, 2019 01:05 PM
g37nightrider
May 23, 2016 01:15 AM
GFTW
May 5, 2016 11:29 PM
Robertomtz
Mar 31, 2016 10:29 AM
armino41
Mar 30, 2016 01:25 PM
