g37xs coupe not speeding up like it used to?
I noticed similar symptoms with my car after installing the exhaust and intake, i babied the car so the exhaust and all that breaks in but then noticed 1-2MPG lower than usually also slightly less power, so i just filled up my tank and reset the ECU before i drove off ( without removing battery terminal ) and car feels new again. it is just probably the cars learning habits or so, i definitely need a tune anyways.
there's even a video on Youtube that shows you how to reset the ECU without a battery pull.
if you can't manage that, then please don't touch the battery, as you might get electrocuted or blow it up.
^ +1.
OP - do a search on this forum and you'll find lots of discussion and DIY about the easy ECU reset. it is just a exercise of pressing down the gas pedal according to a certain pattern and timing. it takes some folks a few tried to master the pattern, but anybody can do it. use a stopwatch if it makes it easier for you.
I think you're just used to the power now... I thought the same when I first got my car. I was scared of the speed the 1st few weeks. I came from driving a F150 so it was a huge adjustment. Now I think its not as fast, then the other day I got after it on the hwy and my car was flying.
ck1109
Nov 3, 2015 12:41 AM
