Carbon Fiber Engine Cover
Old Oct 8, 2015 | 06:00 PM
Dillybar12's Avatar
Dillybar12
Hello all,
I was just about to purchase a carbon fiber engine cover form outcast garage. I was reading on the description of the product and it says that this must be clear coated for the product to keep its shine.
Just wondering if anyone has any tips for clear coating carbon fiber? Is it truly needed?
Thanks,
Dylan
Old Oct 9, 2015 | 09:35 AM
Topher9425's Avatar
Topher9425
If its any kind of quality, it will have a gel coat over it.....then you simply take it to a shop to have it professionally clear coated. Atleast that is what I did with my AIT cover
Old Oct 9, 2015 | 11:00 AM
G-thirty7X's Avatar
G-thirty7X
I would suggest using SprayMax 2K Aersol. It's a 2-part catalyzed "glamour" clear. Works very well and holds up just like factory clear.
SprayMax 3680061 Urethane Clear coat Spray
Old Oct 9, 2015 | 02:35 PM
Dillybar12's Avatar
Dillybar12
Any sanding required?
Old Oct 9, 2015 | 02:38 PM
G-thirty7X's Avatar
G-thirty7X
Depends on how well you lay it down when spraying.
If you wanted it to look as good as possible a quick sanding with 2000 or 3000 grit paper and polishing would make it look like glass.
Old Oct 9, 2015 | 03:10 PM
krazyfiend's Avatar
krazyfiend
Planning to do this with my status elite cf engine cover over the winter. Thanks for the reminder about the 2k/2part clear-- I believe you've mentioned it in previous posts before. I've heard nothing but rave reviews from another friend who used it on some motorcycle parts.
Old Oct 9, 2015 | 03:14 PM
G-thirty7X's Avatar
G-thirty7X
Yeah it's great. I started using it on wheels and never went back to the normal over the counter clears.
If you want professional results, that's the stuff to get!
gian13
Oct 2, 2017 08:47 PM
steven92
Oct 21, 2015 03:06 PM
Steveoh187
Oct 9, 2015 04:23 PM
Mattimus
Oct 8, 2015 11:58 AM
Detailed Image
Lighting/Cleaning Products
Oct 2, 2015 08:54 AM
