2008 infiniti G37s Clutch noise -VIDEO-
Old Mar 22, 2015 | 05:57 PM
infinitipro's Avatar
infinitipro
this problem just started recently. when i turn the car on, i hear a weird humming noise and it goes away when i press the clutch. once i release the clutch it comes back. it happens when its in neutral and driving.
VIDEO:
Old Mar 22, 2015 | 08:29 PM
vqsmile's Avatar
vqsmile
Uhmm, your video is private.
Old Mar 22, 2015 | 09:09 PM
infinitipro
it should work now
Old Mar 22, 2015 | 09:39 PM
vqsmile's Avatar
vqsmile
Yeah, although the exhaust rumble overtone is pretty strong, it does not sound like just the classic clunking gear noise that is common. It sounds more like a bearing noise to me. Is it possible to post another video, just like that one, but with you slowly revving the motor so we can hear how/if the sound varies with engine rpms?
BTW, nice kicks
Old Mar 23, 2015 | 10:36 AM
infinitipro
after doing a lot of research, ive pretty much narrowed it down to the "input shaft bearing" does anyone else agree? how much is the replacement
Old Mar 23, 2015 | 10:48 AM
epenbecks's Avatar
epenbecks
how many miles on yours? did you change the transmission fluid?
Old Mar 24, 2015 | 07:17 AM
infinitipro
80k and no i havent
Old Mar 26, 2015 | 03:58 PM
infinitipro
will changing the transmission fluid fix the problem? the sound is a loud humming. not as bad as other people on youtube
Old Mar 26, 2015 | 04:47 PM
epenbecks's Avatar
epenbecks
you can try. it happened to me when i had G35, with the same noise. i changed the transmission fluid and the sound disappear.
Old Mar 27, 2015 | 10:14 PM
infinitipro
any other suggestions? ill try changing the transmission fluid sometime soon
Old Mar 27, 2015 | 11:22 PM
vqsmile's Avatar
vqsmile
If it's a bearing, it will need replacement. I will say this is very unusual/atypical though, so again my question: Is there any chance this was a flood car?
Old Mar 28, 2015 | 12:14 AM
infinitipro
no its not a flood car. its clean title.
Old Apr 6, 2015 | 01:49 PM
Thirty_Seven's Avatar
Thirty_Seven
Same EXACT noise from my '08 S. Only happens when the clutch isn't being pressed.
Changed the fluid today and the noise is still there. I'm 99% sure it's the throwout bearing, which would explain why it goes away when it's pressed (because now there's pressure on it).
Anybody know approx. how much a shop would charge to replace it?
Old Apr 6, 2015 | 01:58 PM
infinitipro
its not the throw out bearing. its the input shaft bearing. I just ordered fluid so its coming any day now. The noise isn't as bad as other people so that's why I have slight hope this fluid change will work.
Old Apr 7, 2015 | 10:47 AM
spinna001's Avatar
spinna001
could be throw out bearing
