Is it true..
Old Nov 22, 2014 | 05:12 AM
LarryG's Avatar
LarryG
Is it true..
If you do not use Nissan Matic-S fluid for your transmission fluid, you automatically void your warranty?
Old Nov 22, 2014 | 09:23 AM
AroundTheG37's Avatar
AroundTheG37
I don't know for sure and it probably depends on your dealer but I'm of the understanding as long as you use the same weight they can do no such thing. Even if it were the case the only thing it could void is transmission related parts and they would still have to prove the oil caused whatever problem you might incur.
Old Nov 23, 2014 | 09:35 PM
blackfunk's Avatar
blackfunk
But why risk it? The risk/reward doesn't add up. Even if you get it for free you stand to loose quite a bit for a couple bucks.
Old Nov 24, 2014 | 07:09 AM
warped ideas's Avatar
warped ideas
A quarter past stripped
I don't think that can be true. It would be like them voiding the warranty on your power train because you used Mobil 1 instead of the recommended (add any name here)
You know, transmissions are a very costly part of the car. I'd have the dealer do ANYTHING related to it, and let them use whatever the hell it is they want to use. Just my .02
Old Nov 24, 2014 | 01:14 PM
JT2014's Avatar
JT2014
BS, as long as whatever fluid you use meets the OEM specs your fine. Dealers in general for all car makes do everything & anything to get out of warranty work.
Old Nov 24, 2014 | 04:17 PM
canucklehead's Avatar
canucklehead
i remember reading that the old Matic-J fluid for the G35 slushbox was mandatory, and that any independent shop familiar with Nissan would not use aftermarket fluids. i'm not sure if the Matic-S has the same stipulation, but that anecdote from the Matic-J fluid stuck in my head because it seemed unusual to me. that Nissan fluid must have had a novel formulation for which the slushboxes were very sensitive to.
Old Nov 24, 2014 | 05:43 PM
Need 4 Speed's Avatar
Need 4 Speed
Pretty sure its up to the dealer. I have used other the Nissan oil that meet the requirements all the time and no problem.. Maybe ask another dealer..
Old Nov 24, 2014 | 07:45 PM
Cr0tchf4i's Avatar
Cr0tchf4i
I recently had my manual tranny fluid replaced- I asked if i could use something aftermarket and they said absolutely not. They'll look for any reason to void a warranty.
Old Nov 25, 2014 | 12:08 AM
vqsmile's Avatar
vqsmile
Ehh, that's some serious BS right there. Whoever told you that didn't know their $%1t. I had my 6 speed manual replaced under warranty at 45K miles. They asked if I ever changed the gear oil, when I said yes and that I had done it myself at 30K, they only wanted to know that the brand/weight/spec fluid I had used was consistent with what was in the owners manual. The biggest thing they seemed to be concerned with was whether or not I used GL-4 instead of GL-5 oil. Once I told them what I used (it was a Redline product), they were satisfied and didn't even bother to check for receipts.
As far as Matic-S for the automatics, I wouldn't dare risk using anything else. As was mentioned previously, it is just not worth the hassles. It CLEARLY states in the owners manual not to use anything else or you risk voiding warranty. I mean, it's not like they're not straight up warning you, direct from the factory, in writing!!
Old Nov 25, 2014 | 04:01 AM
LarryG's Avatar
LarryG
The manual just says 'Recommended' and not 'Required'.
https://owners.infinitiusa.com/conte...-G37-Coupe.pdf
Page 9-2.
A tech told me that you are able to use different transmission fluid as long as all the spec matches.
Old Nov 25, 2014 | 11:44 AM
vqsmile's Avatar
vqsmile
Page 9-2.
Sorry Larry, but perhaps you've misread the manual. See the note underneath for the definition of asterisk number three:
*3 : Using automatic transmission fluid other than Genuine NISSAN Matic J ATF will cause deterioration in driveability and automatic transmission durability , and may damage the automatic transmission, which is not covered by the INFINITI new vehicle limited warranty.
(Note: Matic S is backwards compatible and has replaced Matic J as the correct fluid. You cannot buy Matic J any more.)
Old Nov 25, 2014 | 12:20 PM
canucklehead
^ yeah that sounds identical to the spec from the G35 using Matic-J. so it sounds like nothing has changed and the AT guys must stick to the OE fluid, now called Matic-S. this is not the same case with 6MT guys as mentioned above. i'm using Redline and love it, but if i was driving a G37 7AT i would certainly stick to the Matic-S fluid. clearly the Matic fluids have a propriety formulation that was developed specifically for the Nissan slushboxes.
Old Nov 25, 2014 | 12:50 PM
ANMVQ's Avatar
ANMVQ
How'd you even change it and not have the dealer do it. The units are sealed and the shop would need a special Nissan tool. Heck if the spent the money on the tool why not have the Nissan fluid?
Old Nov 25, 2014 | 01:16 PM
vqsmile's Avatar
vqsmile
^^ Unlike the later 7AT, the 5AT in the '08 coupe still had a simple fill spout.
Old Nov 25, 2014 | 01:22 PM
LexiG37's Avatar
LexiG37
If you can afford an Infiniti, you should be able to afford the proper fluid. $7 for the knockoff vs $14 for the good stuff.
