i think the dealership messed it up..
Old Jul 25, 2014 | 01:28 AM
Flip_x's Avatar
Flip_x
Hey guys
I had the dealership do a drain and fill on a 7at yesterday. 39k.. anyways now when i do a semi hard brake and get going again the car revs up alittle and then it catches. sometimes its violet if the brake is hard.. any ideas before i go to the dealership tommorow?
Cedric
Old Jul 25, 2014 | 01:54 AM
BeefMaster's Avatar
BeefMaster
Happens to mine too and had that since the car was new. That's just how the car is. You brake hard and then gas and the RPM just flies wildly until it gets "caught". I mean if you think about it, if you accelerate from a hard braking, the car's downshifting fast and you just surprise it with a hard press. Sounds normal to me.
Old Jul 25, 2014 | 02:38 AM
HoldmyMouse's Avatar
HoldmyMouse
It's your engine rev matching the rotational speed of your transmission when it downshifts. It is perfectly normal under hard braking situations. Putting your car into DS Mode will make it happen more frequently. Just FYI, driving/rolling down a slope sometimes will do that too. But it shouldn't be "violent" when it downshifts though. It might be a bit less smooth but shouldn't be too harsh.
Old Jul 25, 2014 | 03:28 AM
Flip_x's Avatar
Flip_x
My bad. It's when I come to a full stop.. I had the tranny update the first month I had it. When I start to go again it feels like I dumped the clutch on a manual car.. The slip light goes on.. It happens if I brake hard to a stop. And when I get going it takes a second to catch. And there is a loud clunk.
Old Jul 25, 2014 | 08:31 AM
chilibowl's Avatar
chilibowl
At 39K...I dont believe it should be doing this. Ive driven my brothers G35X 5AT and his car has 120K on it and that transmission is just f*cking awesome for an automatic.
What youre describing almost sounds like clutch pack slip or a bad torque converter. An auto box should not have clunking other than moving from reverse into 1st gear while the car is still moving backwards.
Old Jul 25, 2014 | 09:58 AM
Ryne's Avatar
Ryne
The Steering Wheel Guy
The rev matching of downshifts is really only noticeable for me under hard braking in DS mode. OP's issue doesn't sound related. No one has mentioned yet that the AT transmission fluid is a one time fill, and does not appear in any recommended maintenance interval that goes through 120K miles. If it ain't broke, don't fix it. Hopefully the dealer didn't recommend that service, if so, they kind of took you for a ride - especially at 39k miles.
https://owners.infinitiusa.com/conte...ance-guide.pdf
Specific quote from the linked text. Unless of course you were towing campers or trailers with your coupe.
Good luck, hopefully they get everything running how it should be and don't brush off your problem.
Old Jul 25, 2014 | 11:27 AM
HoldmyMouse
^^^ that's what I thought too. A closed system shouldn't require attention at 39k. Op you better take it back and ask about your problem. Be sure to ask for a tech to ride along and not just drop it off. Or else they will just write your concern as normal or unable to replicate. Good luck and keep us updated
Old Jul 25, 2014 | 04:17 PM
chris_s's Avatar
chris_s
isn't the ATF supposed to be "lifetime"? why are we changing it?
Old Jul 25, 2014 | 04:54 PM
HoldmyMouse
Probably 100k but not lifetime for sure.
Old Jul 25, 2014 | 08:02 PM
Yep, 100k miles is a reasonable time to change it out, or you can do a few drain & fills after 60k so the fluid will be mostly fresh after 3-4 drain & fills.
I'm waiting until 100k though.
Old Jul 26, 2014 | 02:55 AM
Flip_x's Avatar
Flip_x
Well I can repeat it easily. I can go 5mph and brake hard and try to go again. And it takes a second to catch... Reason why I did it was 30k was recommended to do it so since it's still under warranty I just did it so they can't tell me I neglected it.. But when I saw them drain it the fluid was black and not red.. It also ran alot better except for this problem. I think the guy just didn't fill it up all the way. So when I brake the fluid moves forward and starves it..
Old Jul 26, 2014 | 11:23 AM
telcoman's Avatar
telcoman
Hey guys
I had the dealership do a drain and fill on a 7at yesterday. 39k.. . any ideas before i go to the dealership tommorow?
Cedric
Did the dealer recommend this or did you just tell them to do it?
Never try to fix anything that isn't broke.
My 74 Mazda RX4 was my last auto transmission vehicle and had it for almost 150k miles.
Never changed the transmission fluid and it ran fine till the day I sold it 17 years later.
Telcoman
Old Jul 27, 2014 | 09:59 PM
jet-tek's Avatar
jet-tek
I use to do my acura at 5k do to there reliability issue! did the g at 30k which was also fairy dark .better safe than sorry. fluid is cheap-that the old fluid.let us know what they say?
Attached Thumbnails i think the dealership messed it up..-passport-tranny-001.jpg
Old Jul 28, 2014 | 03:20 AM
Flip_x's Avatar
Flip_x
At first the tech said it was normal. We drove another one didn't do it.. He was puzzled so I gotta bring it in Tuesday they have to talk to the engineers but.. Sounds like the torque converter is causing it to not catch quick... All they did was drain and fill not hooked up to any machines. And they didn't even have the special tool.. Wtf!
Old Jul 28, 2014 | 08:56 AM
Trunks333's Avatar
Trunks333
39k. Way too soon. Did you ever get a software update?
