New here, couple of questions
Hi guys, just purchased a used 2011 G37 coupe with around 16k miles and have a couple of questions.
1. Should I take it to the Infiniti dealership and have it checked out for any TSBs that may need to be applied and just have an overall checkup? They charge $125 for the multipurpose inspection.
2. Car came from Houston and I live in a smaller town. I'm sure that the car was driven mostly on the highway and my town will be more stop and go. Should I reset the ECU?
First of all, welcome to the forum. Second, 2011 with 16,000 miles?!?
Nice find. You might just be able to email the dealership to see if there are any TSB's that need to be applied, however, if you bought from an Infiniti dealership they should be keeping everything up to date on that end.
Resetting the ECU can't hurt, but probably isn't necessary.
Try the pedal mode for ECU reset or just disconnect the neg terminal?
What's the best first mod? Intake?
My buddy GFN started this thread just for your situation. Check it out. https://www.myg37.com/forums/newbie-...rformance.html
Depends..... Do you want noise or looks? I'd drop it and throw some nice wheels under her. Then start saving up your hard earned money because it will burn up quickly when the mod bug bites. LOL
Do your research before making any purchases, you'll be better off for it.
You may regret short ram air intake tubes in the future. They are easy to install and filter maintenance is a breeze. The draw back is lower power then a true CAI after you end up getting a tune.
Intake
Cusco strut bar
Springs/Camber
Exahust
Simran Mann
Sep 13, 2015 01:51 AM
