Weird A/C issue
Old May 16, 2014 | 06:41 PM
rlaskqfP's Avatar
rlaskqfP
Weird A/C issue
I'm driving 2010 g37 coupe non-sports. Since around a year ago my a/c started having some problems. It works perfectly fine when I'm driving (saying when my tires are rolling), but when I stop like at the signal or any other spot, the air gets warmer immediately. I can feel it warmer, I can smell it getting warmer. Anyone had this problem yet? Anyone have clue why it's happening? and if anyone know some auto repair shop around OC or LA area please inform me. I've found some a/c problem threads here but it's not the same as my problem. Thanks all.
Old May 18, 2014 | 03:58 PM
nissanlvr's Avatar
nissanlvr
There's a TSB for this - ITB10-051 "A/C Blows Warm at Idle".
Basically, the idle on certain 2010 G's was programmed to be too low. When the idle gets low, the car shuts off the A/C compressor to reduce engine load. Therefore, you no longer get cool air until you accelerate, raising engine speed, and the car switches the compressor back on.
The fix is just a software update. Take it to the dealer for this.
Hope this helps!
Old May 20, 2014 | 10:56 AM
guy from norcal's Avatar
guy from norcal
mine does this. so when stopped i put the car in nuetral ( 7at ) and rpms go up and air gets cold
just don't forget to put it back in D when light turns green. scares the hell out of you the first time
Old May 20, 2014 | 02:33 PM
nissanlvr's Avatar
nissanlvr
Lol. Wouldn't it be easier to just get the problem fixed?
Old May 20, 2014 | 02:39 PM
telcoman's Avatar
telcoman
As others have mentioned take it to the dealer for any TSB updates. Make sure it is not low on freon
Good luck
Telcoman
Old May 20, 2014 | 03:16 PM
guy from norcal
perhaps it would. i didn't know there was a tsb on it
Old May 20, 2014 | 04:19 PM
rlaskqfP's Avatar
rlaskqfP
Hope this helps!
Thank you so much for the perfect answers guys! Now i just need to make some time to go to dealership
Old Jun 1, 2014 | 05:07 PM
Glock Diver's Avatar
Glock Diver
I have the exact same issue with my 2010 G37 sedan. It would start blowing warm air, unless I cranked the A/C temp down to 65.
Took it to the dealership 2 months ago, and they replaced the compressor under warranty, but it didn't fix this problem!
I will take it back tomorrow to fix this under the TSB.
Old Aug 27, 2020 | 09:09 PM
singhsarabjit's Avatar
singhsarabjit
Hello Glock,
Did you get your issue fixed? I am having same issue.
Please let me know.
Thanks
Jeet
vamarris
Dec 9, 2018 11:10 AM
Prometheus
General Tech Questions
Nov 9, 2015 01:23 PM
Awgd8
Sep 30, 2015 06:22 PM
Irishcurtis
Sep 30, 2015 11:39 AM
Slapshot1
Sep 27, 2015 08:40 AM
