Rear sunroof drain leak unfixable?
Hello all, new here. Looking for some advice. I own a 2010 G37x coupe and love the car.. Recently during any kind of hard rain or a carwash, i have a wet patch of water on the panel between my rear windsheild and driverside rear side window.. A body shop told me they blew out the drains and it was fixed but it continues to leak and infiniti in greenwich ct sounds unsure if they can solve it.. Anyone had this same problem or have any ideas of a better solution?
Once I had a issue, but it was an easy fix.
Good luck with the repair.
Chances are that the hose has come loose from one of the drains for the sunroof. I had to remove the headliner and extend the hoses on my Lincoln LS bcause they had shrunk and pulled loose from the drain tubes. I'm sure it's repairable, you just need to find someone capable of doing the job correctly. Good Luck
m3clubracer
Sep 13, 2015 09:01 AM
tite_tite
Aug 22, 2015 05:21 PM
