Need some help
Old Feb 23, 2014 | 04:47 PM
milky's Avatar
milky
Need some help
Hello all,
Yesterday I changed my brake pads and changed my oil. I didn't take off the caliper when i changed the pads, didn't touch any of the brake lines either. This morning when i went outside, i found some clear fluid on the ground. There is some fluid leak coming from the driver's side, right behind the wheel area. I took a few pics cuz i can't figure out what's leaking. The oil is clear, looks like it might be brake fluid? The line to the break isn't leaking, and there is still brake pressure when the brakes are applied. Checked my engine oil level and that's fine as well.
Has anyone else had this problem after changing their brake pads?
Here are the pictures:
Old Feb 23, 2014 | 05:41 PM
Gio37's Avatar
Gio37
Any chance you might of spilled a little fluid when you filled the reservoir ?
Old Feb 23, 2014 | 10:51 PM
milky's Avatar
milky
Hmm now that I think of it, I think that's what happened.. lol thank you I'll double check
