Update:
Much wider wheels to come for next spring.
I noticed the right front fender flare is missing a screw most likely due to its close proximity to the headlight; you could always cut a screw and glue it on for conformity if you want.
First and foremost....Amazing G,s fellas.They all look amazing..
blnewt: thanks for your help with tire sizing.still undecided.Im very glad to have come across this thread.
Let me introduce myself.Im new to the xs coupe.my last G was an 08s coupe...Now riding in an 13 xs coupe...
I live in Canada so everything seems to require a lot more searching for me.To ship everything to my door is stupid $$$....
So far my list is as follows.
Stillen Gen 3 long tube intake
Eibach pro kit Springs
Vossen cvr,3 wheels on 19-20 undecided atm.
And Motordyne Shockwave cat back exhaust.not sure what cats will work with this exhaust as of yet.
Just talked to motordyne the other day and the Shockwave for our awd coupes.I is just finishing up in R&D.
I was going to go with the Ark exhaust till I saw,somewhat heard motordyne on you tube ect.
So far the only upgrade is tint.lol.Hope to get all other mods up and running in the next 2 months.
Hi Guys, first time poster here! Joined the forum yesterday and been lurking and chasing some info, lots of good information here!
I bought my 2010 G37X Coupe 3 weeks ago and since it's winter here i'm rolling on factory wheels and winter tires... ...so yeah! I'm now shopping for a summer set of wheels... ...and here comes the question!
I've stopped my choice on Niche Targa model but i'm a bit confused about the offset required to get the look i'm after and thought i could get some help on here.
20x10 Rear and 20x8.5 Front is what i'm looking for, or if it would fit without the need of rolling fenders 20x10.5 Rear and 20x10 Front.
I want the wheels to have a nice flush fit into the fenders and still allow full suspension travel with no rubbing. Car will also be lowered at least 1.5inch with a set of BC Racing coilovers.
With AWD you also need to be very careful in tire combinations, if your front to back variance in diameter is over 1% you will probably have issues w/ your AWD system. That said, I'd run a 20x8.5 +25 on 245/35/20 front and either a 20x10 +40 (which you will probably want to run a 10 to 15mm spacer) and a 285/30/20 rear. OR a 20x8.5 +25 on a 235/35/20 front and a 20x10.5 +30 on a 275/30/20. This will give you a flush fit, and your rear fenders are already flat-rolled from the factory, the fronts are semi-rolled (about a 45 degree angle from the fender edge).
Here's the list of 20s that will work and the variance %, as you can see those two combos are excellent
20s
235/35 & 275/30 0.07%
245/35 & 285/30 -0.07%
20s
Please post wheel tire posts in the wheel folder if you have more questions Wheels & Tires - MyG37
Hope that helps!
Brad
Hi Brad, thanks for the in deep answer, much appreciated!
I sure will post pics once fitted on the car, i only have one last question, that i should have mentionned in my initial post, will these tire size have the "stretched sidewall", i want as much as possible to have a "square" sidewall.
