Horrible morning
Old Feb 20, 2013 | 11:30 AM
hechen507's Avatar
hechen507
Originally Posted by Way2flyy
Dnt think battery is dead, can still work radio and all those things fine
Its probably the battery, while it still has charge it not enough to crank. It take around 100+ amps to crank! Even high in the winter, while your radio is probably around ~5amps if it isn't cranked all the way up.
Rad_Slinger's Avatar
Rad_Slinger
Checked oil, n it was low as well as very dark . Could this be affecting startup?
Doubtful, unless your engine seized, but you would have had signs, lights, sounds, warnings when you drove it last time.
So I would say no.
Old Feb 20, 2013 | 11:36 AM
Way2flyy's Avatar
Way2flyy
Originally Posted by Rad_Slinger
Yep....and most of the time you'll be able. Having a "dead battery" just means it doesn't have enough amps to turn over the starter.....unless its completely dead, there's gonna be juice left for lights and radio. Also, how old is the battery? Could have a bad cell which would also affect amperage.
Srsly, try to jump it. It's the simplest thing to do at this point.
Ok thanks, gonna try the jump. As you can tell I'm a total noob, Tryna learn from you guys here lol.
Old Feb 20, 2013 | 11:37 AM
Rad_Slinger
Everybody gotta start learning somewhere.
Let us know how you made out.
Old Feb 20, 2013 | 03:42 PM
Way2flyy's Avatar
Way2flyy
Finally got it started, needed the jump. Thanks guys
Changed tire to spare, and bringin to my mechanic for much needed love.
Old Feb 20, 2013 | 09:53 PM
Rad_Slinger
Glad you got it worked out and we could help....a little.
Old Feb 20, 2013 | 10:08 PM
TheGanglyGoon's Avatar
TheGanglyGoon
sometimes my battery clips become loose and all i have to do is retighten the bolt. Worth a try..
fuzzed
Aug 21, 2020 09:35 AM
dedmanchan
Oct 6, 2015 05:43 PM
mjnoles1
Oct 4, 2015 10:27 PM
cyberone28
Sep 23, 2015 01:56 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
