Map light rattle due to subwoofer
Old Feb 4, 2013 | 12:23 PM
ai3j50's Avatar
ai3j50
I just installed 2 10" subs in the trunk of my G coupe. The Map light console gives a bad rattle. The rattle was there before the subwoofers were installed but not as prominent. If I hold the space between the sunglasses holder and the lights then the sound goes away. Is there any way to permanently fix this problem or reduce the rattle?
Old Feb 5, 2013 | 01:30 PM
quakerroatmeal's Avatar
quakerroatmeal
Take it out and stuff either some foam, of sound deadened behind it.
Old Feb 5, 2013 | 01:34 PM
Rad_Slinger's Avatar
Rad_Slinger
Or....turn the bass down
Your ears will thank you
Old Feb 5, 2013 | 02:01 PM
BLamb's Avatar
BLamb
I usually just stick these between whatever is rattling: Surface Gard Assorted Light-Duty Self-Adhesive Felts 46 Pack-9425 at The Home Depot
Old Feb 5, 2013 | 02:32 PM
Take it out. Spay or brush on some sound deadener on it back of it. Done.
Old Feb 5, 2013 | 03:43 PM
1scG37s's Avatar
1scG37s
I had this issue, and tried adding some foam padding. it helps but dynamat help's even more since it weights it down. This is prob. the cheapest solution.
give it a try best of luck.
E/O 3/4 in. x 7/16 in. High-Density Rubber Foam Weatherstrip-R734H at The Home Depot
-1scG37s
Old Feb 11, 2013 | 12:22 PM
ai3j50's Avatar
ai3j50
Ok thanks for the input guys. I'm going to take it down and go with some sound deadener.
redlinernyc
Feb 29, 2016 11:06 PM
theKfactor
Sep 12, 2015 09:35 AM
m3clubracer
Sep 7, 2015 05:14 PM
