60K Service
I bought a 2008 G37 Coupe 6MT
recently with 60K miles. Since this is the first time I wanted to get it serviced from stealership assuming that it will be close to $500. But looking at the Infiniti website Premium is around $1000. I really don't want to spend that much for this service. I checked online and read bunch of threads here and looks like I can DIY most of them. This is the 60K list from Infiniti website
Replace engine oil and filter
Replace in-cabin microfilter (if equipped)
Lubricate all locks/hinges
Replace differential oil (if applied)
Replace engine air filter
Replace engine coolant/flush system
Replace engine drive belts
Replace manual transmission oil
Replace radiator cap
My first question is can I do all of these myself? I don't have a lot of experience with cars except oil changes and wheels changes.
Next question is where can I get parts for this service? Is this a good deal from SewellInfiniti? All the below for $177. If this is not a good deal, where can I get all the parts?
Since the above list doesn't cover all the items, where can I buy the remaining?
What are the good brands? Do I have to do all of them at the same time or can I do them whenever time permits?
My next question is, is there anything missing from this list for the 60K service?
My last question is(similar to 1 but with details
), I checked and could find videos for many of the above items. Is everything in this list doable? I have tools (wrenches, screw drivers, etc). I have 2 hydraulic jacks and 2 stands. I guess I am good from the tool stand point.
I searched this site several times, but most of the previously asked questions was weather its worth it or not etc? So I would assume this is not a repost
Once I have all the answers, this will be a great sticky for others. Thanks in advance
P.S: Apart from the money I am going to save, I really want to work on my car. Please help
recently with 60K miles. Since this is the first time I wanted to get it serviced from stealership assuming that it will be close to $500. But looking at the Infiniti website Premium is around $1000. I really don't want to spend that much for this service. I checked online and read bunch of threads here and looks like I can DIY most of them. This is the 60K list from Infiniti websiteReplace engine oil and filter
- Oil Filter
- Engine Air Filter
- Interior Cabin Micro-filter
- Left & Right Rubber Wiper Inserts
- 2 Drive Belts
- Radiator Cap
- Upper & Lower Radiator Hoses
- Replace differential oil (if applied)
- Replace engine coolant/flush system
- Replace manual transmission oil
), I checked and could find videos for many of the above items. Is everything in this list doable? I have tools (wrenches, screw drivers, etc). I have 2 hydraulic jacks and 2 stands. I guess I am good from the tool stand point.I searched this site several times, but most of the previously asked questions was weather its worth it or not etc? So I would assume this is not a repost
Yes you can DIY all of the items mentioned about. $500 is ludicrous for an afternoon's worth of work and a 6 pack. Brands of what types of fluids to use have been discussed on this forum ad nauseum. Check the DIY section for a lot of this info along with using the forum's search feature. You will find a wealth of information and learn some new things.
Yeah, all that can be done following the DIYs here on this forum, that's how I did mine and all I had done in the past before was just a few oil changes.
I did all these from your list myself in my garage:
These I haven't:
Lubricate all locks/hinges (seems pretty easy)
Replace engine coolant/flush system (I've been thinking about this one lately)
Replace radiator cap (self explanatory
It looks like you have the right attitude and actually want to do this, and that is a big step forward. As SwissCheese said, you'll need to do your homework and get the proper tools and all that. All the information you need is on this forum, believe me.
Your car is going to feel so much better once you're done, especially if you do your engine, differential, and transmission on the same day.
These I haven't:
)It looks like you have the right attitude and actually want to do this, and that is a big step forward. As SwissCheese said, you'll need to do your homework and get the proper tools and all that. All the information you need is on this forum, believe me.
I recommend Redline MT85 for the transmission oil, you'll need 4 quarts. I used Motul 300 but didn't like it because it was too notchy. You can purchase it from conceptzperformance. For the diff I'd also use Redline but 75W90. You'll need a pump from kragen or pep boys which is cheap under $10. Refer to DiY guides before proceeding.
Thank you!Actually I am compiling a list of DIYs for 60K service and will put it together
We have mandatory vacation starting from Christmas to New Year and planning to do these at that time. Thanks again
stealth210
General Tech Questions
27
Jul 26, 2017 06:48 PM
delfinparis
Nov 16, 2015 02:26 PM
Junchao Sun
25
Oct 1, 2015 12:41 PM
