Question about MPG...Need some assistance
Old Nov 7, 2012 | 07:32 PM
SRG's Avatar
SRG
Whats up everyone, been a while since I've posted on here. Been busy traveling and djing =)
So my main question is this...Ever since I put my Stillen CAI's on. I feel that the power went down a little and started using more gas. I have the CAI, HFC's, fujitsubo exhaust and i actually recently removed the y pipe because it was making horrible noise so i'm back to the stock y pipe...
I want to make the best decision which will benefit me...Should I go back to the stock intake or, should I get the uprev tune which might help with the way everything flows?
I also have stock filters that came with the CAI (not k&n filters), maybe this can be an issue also?
All the help would be appreciated!
Old Nov 8, 2012 | 01:24 PM
pgviper's Avatar
pgviper
I would def get a tune. Tune will make everything run more efficiently which will make driving smoother and allow for better gas mileage.
Old Nov 8, 2012 | 04:04 PM
SRG's Avatar
SRG
thanks for the advice, i was trying to figure out what to do and I think i might just do that if I decide to keep her around for another year or two
Old Nov 8, 2012 | 05:27 PM
ViEtNaStEe's Avatar
ViEtNaStEe
How many miles have you put on the car after you had your intake installed? Did you reset the ecu after you did the install?
I think the ecu needs some time to learn how to adjust with the increased airflow.
Old Nov 10, 2012 | 10:05 AM
SRG's Avatar
SRG
I'm sure over 5,000 miles now. I have reset the ecu a few times. Maybe it's just me... But I definitely feel the car is slower after all of the mods
Old Nov 10, 2012 | 11:38 AM
canucklehead's Avatar
canucklehead
Sometimes intake and exhaust mods sacrifice low end torque for more power up high in the rpm range. Maybe you lost a bit down low which will make it feel slower since most time is spent under 3k rpms.
Old Nov 12, 2012 | 04:41 PM
SRG's Avatar
SRG
You're probably right canucklehead, I'm debating about just going back to stock intake cause I really do drive mostly slow lol
Old Nov 12, 2012 | 10:13 PM
venkatsharat's Avatar
venkatsharat
yeah low end suffers with "bolt on" mods especially CAI and bigger exhausts. ...there have been some heated arguments regarding this.
Old Nov 14, 2012 | 01:01 AM
SRG's Avatar
SRG
What to do... What to do
redlinernyc
Feb 29, 2016 11:06 PM
gdaelemans
Sep 15, 2015 12:20 PM
nbast
Sep 14, 2015 12:39 PM
Detailed Image
Lighting/Cleaning Products
Sep 14, 2015 07:24 AM
gdaelemans
Sep 13, 2015 09:36 PM
