Bug report
Bug report
Just thought I'd warn you guys of 2 bugs I've encountered with my 08 which could 100% lead to battery drain issues.
1) I shut off the car and the NAV screen stayed on. Would not turn off. I got out, waited a few minutes, it still didn't turn off. I had to start the car and shut it off again to make the nav screen turn off.
2)Top lights stayed on. For some reason the top 2 lights would not turn off unless I press them to turn them off (never pressed them to turn them on in the first place).
Trying to remember the third one but I'll keep you posted
2)Top lights stayed on. For some reason the top 2 lights would not turn off unless I press them to turn them off (never pressed them to turn them on in the first place). This has happened to me twice already.
Fortunately, this hasn't happened to me. Thanks for the heads up!
For your 2)... do you think that switch/botton the door pushes when you shut the door is not working correctly? Maybe that's why your dome lights are staying on?
I don't think that's it. For some reason the car thinks the dome lights were pressed to turn on so they stay on permanently even when the switch on them is set to [off].
i also do not have these problems in my 08. although i dont have the nav unit i still have a screen that turns off when i shut off my car.
sounds like a wiring issue with both of your problems. but im no expert.
With car systems computerized, there will be bugs and glitches showing up every once in a while. Just because you guys haven't experienced these issues does not mean you won't. How many people who had a dead battery do you think could have had a Nav screen left on or a light stuck on?! Do you really think people pay attention to whether their lights are on or not when they get out of the car in the day time? It nearly slipped my mind.
This is not a wiring issue. If I take it to infiniti, they will give my car back and say "we cannot recreate the issue". The purpose of this thread is to tell you guys to keep an eye out for these things so you don't have a dead battery the next morning.
i see that your only trying to help. how often do these things happen on your car? bugs/glitches do happen in a digital world. but if it happens often than i would suspect theres more going on than just a bug/glitch.
out of 3.5 years of ownership ive not once encountered the 2 items you've listed. my battery has died on me once when i was trying to figure out how to program my garage door opener and left the car in accessory for too long. thats why i think its just an isolated case rather than a widespread bug/glitch affecting all 08s.
It sounds to me like you have a mechanical or electrical problem. Someone suggested maybe the switch in the door that detects whether or not it is closed is stuck? You incorrectly addressed his comment as if he were talking about the switch on the light dome.
