Need opinion on modifying my Fast Intentions exhaust.
As the title states I wanna get your guys input on this. As you can see in the pic below the tips are touching my rear diffuser. This is the passenger side, drivers side looks the same just opposite obviously. Exhaust shop said they could cut the exhaust between the muffler and the flange, center it, and re-weld it. My question is would you guys do it?
I wanna make it clear I have no complaints about the exhaust and I love it. Just don't like it rubbing on the diffuser.
Thanks
Thanks
Did you try lowering it by adjusting the exhaust hangers near the tips? You can either remove the exhaust and rubber hanger and bend them down a little bit or take them off and put spacers underneath it and bolt it back up, dropping it lower by the size of the spacer used. I'd suggest maybe 1/2" at to start. You may need to buy 3 bolts per side that are 1/2" longer (or whatever size spacers you choose).
Another option is to simply heat up and slightly bend the hanger that's welded to the tail pipe so that it hands down and toward the center a little bit.
This is what I'd try before cutting anything. A cheap and easy solution that may work.
I would lossen all bolts that hold the FI system together at the pipes both at the mufflers and the forward ones at the stock pipes. Have someone hold the tips were you want them then tighten it back up. I removed my FS setup a couple times now and each time the tips ended up in a little bit of a different location.
Tuckermaclain
Oct 5, 2015 11:41 PM
Slapshot1
Sep 27, 2015 08:40 AM
