2008 service visit ??
Jus had my car serviced at a new dealership and they told me a list of things I needed for my car, I have a 08 g37 base got w/ around 44k I now how 49k, other than regular oil change, filters?? Which of these are essential?
Air filters
Fuel induction service
Hepa filter
Ac clean
Coolant flush
Thanks....
Air filters
Hepa filter
Ac clean
Coolant flush
Thanks....
Did you get any of those services done/changed previously and when?
I change my air filters myself when they get visually dirty around 15k-20k.
Fuel induction?? Is your G's performance bad or clogged fuel line?
A/C (HEPA) filter recommended every 15k i think... I do it my own every 15k-18k.
AC Clean? what is that...
Coolant flush I'm at 56k haven't done it yet. I drive through a lot of traffic stop and go's. If you have the money do it, i would.
I'd do the engine and cabin air filters. A coolant flush wouldn't hurt either.
Also, brake fluid flush is recommended if its never been done - brake fluid look dark, or light like honey? Changing the rear end oil is a good idea too. Also clutch fluid if its a manual.
If you got have a brain and some mechanical ability, you can do all of these yourself. Definitely the filters.
Please let me you know how to do most of this stuff. Main thing you want to worry is you're oil change. I changed my in cabin air filter at 20k and 40k (and this is not that hard trust me). Next thing you should do is the clean out the intake air filter (once again VERY easy).
Coolant Flush might a be the only thing I would take it in for. Everything else is pretty easy. Do it on you're own and in the process save $1200
plus what tools would i need in order to get this done. thanks
delfinparis
Nov 16, 2015 02:26 PM
Junchao Sun
25
Oct 1, 2015 12:41 PM
