what DRL, snow tires, and interior led lights? G37 coupe 2008 black
Old Dec 20, 2011 | 05:46 PM
BradH427's Avatar
BradH427
Just bought a 2008 G37s coupe with 18,000 miles on it and I was wondering what LED DRL people use, what snow tires to put on, and where to get lights to change the interior lighting to led super white?
Old May 3, 2012 | 11:13 PM
LanHarjochee's Avatar
LanHarjochee
Lightbulb
The many places ~ ~ The key is to see what needs, what color you need, led strip lights the need which the price, you need the kind of brand, if you do not understand, flexible led strip then you can go to the website to check the LED Light Bars so that you can buy their desired products!
Old Jun 4, 2012 | 07:29 AM
ledlight's Avatar
ledlight
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <wrawingGridVerticalSpacing>7.8 磅</wrawingGridVerticalSpacing> <wisplayHorizontalDrawingGridEvery>0</wisplayHorizontalDrawingGridEvery> <wisplayVerticalDrawingGridEvery>2</wisplayVerticalDrawingGridEvery> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:SpaceForUL/> <w:BalanceSingleByteDoubleByteWidth/> <woNotLeaveBackslashAlone/> <w:ULTrailSpace/> <woNotExpandShiftReturn/> <w:AdjustLineHeightInTable/> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> <w:UseFELayout/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> LED Lights are one of the best lights used in the field of lighting. Based on its efficiency and durablitiy this LED Lights are your first choice in home improvement. E27 LED Outdoor Spotlight
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
sydnrusty
Nov 21, 2015 10:42 PM
dAgent
21
Aug 6, 2015 02:15 PM
