Just got my Autokits-X CF V2 Rear Diffuser.
Old Nov 21, 2011 | 05:16 PM
supadice's Avatar
supadice
Can anyone give me tips and or reccomendations for installing.
Old Nov 21, 2011 | 06:32 PM
DPE G's Avatar
DPE G
Clean the bumper VERY well. I've had to retape mine 4 times and i clean mine with alcohol prep pads and each time.
Old Nov 21, 2011 | 06:35 PM
SwissCheeseHead's Avatar
SwissCheeseHead
I know this isn't helpful but...Post pics when you're done!!
Old Nov 21, 2011 | 06:52 PM
soolman32's Avatar
soolman32
Clean the bumper well and take your time to get the diffuser line up properly before pressing it firmly into place.
Old Nov 21, 2011 | 08:46 PM
huwee06's Avatar
huwee06
Took me 3rd attempt to figure how to get mine lined up correctly; I started from the middle area (license plate) make sure you have the diffuser flush with the indent of the area. I peel off the 3M section at a time so you won't accidently have it stick onto the bumper at the wrong location. Helped my buddy do his took only one try!!
Old Nov 21, 2011 | 10:05 PM
Chi-City-G's Avatar
Chi-City-G
I have installed both V1 and V2 diffusers myself as well. Take note of what the others said, take your time and you'll be fine first try. Make sure it is not too cold when appying it or do not do it outside as the 3M will fasten much better and create a better seal initially if it is warm. If it is cold then you may want to consider applying it with a hair dryer or heat gun.
Old Nov 21, 2011 | 10:09 PM
Soliditude's Avatar
Soliditude
I'm waiting for my V1 CF Diffuser to arrive this week, so thanks for this thread and the previous response. It'll be freezing around the time to install it, so I'll definitely have to use a dryer or something.
OP, yes, clean bumper very, very well and alcohol prep it nicely. Line it up a few times, then peel tape.
Old Nov 21, 2011 | 10:10 PM
myk1013's Avatar
myk1013
all good pointers... here's more.
I super glued the grill from the rear just to be safe.
I also added more double sided tape than what's on the diffuser already.
I added zip ties to the middle part of the diffuser and around the bumper underneath the license plate area. ** just to be safe.
...just make sure it wont be visible once you put the licens plate back on.
Old Nov 21, 2011 | 10:20 PM
Soliditude's Avatar
Soliditude
+1! I definitely agree. Especially with adding more 3M tape yourself. I'm definitely doing that.
Old Nov 22, 2011 | 04:42 AM
G37SBS's Avatar
G37SBS
Which 3M double sided tape is good? I search for 3M double sided tape and there are alot of different kind came up.. Also Where is the best place to get 3M double sided tape
Thanks
Old Nov 22, 2011 | 06:26 AM
ANMVQ's Avatar
ANMVQ
Hmm all good advice, I also removed the center brackets bolted the to the car first then to the diffuser, I also removed only on side of the tape to start the install. I did one side at a time, Clean the bumper with window cleaner, An only took me one time :/.. Only thing I would change is the supplied screws? They rust in like 15 mins LOL.. Still need to change mine.
Old Nov 22, 2011 | 11:26 AM
_ant_'s Avatar
_ant_
good luck and post pics after install man
Old Nov 29, 2011 | 10:02 PM
BL1024's Avatar
BL1024
This is probably a really stupid question.. But, is this diffuser basically you just stick it on to your rear bumper? Like you dont have to cut out anything on your OEM bumper or get a whole new rear bumper correct? Just buy this diffuser, line it up, and stick it on? Thank guys!
Old Nov 30, 2011 | 12:39 AM
Soliditude's Avatar
Soliditude
Yes, that's exactly what you do. If you notice, our rear bumpers on the non-IPL models kind of have a shape cut out in the bumper... Almost like they intended it for diffusers. You align it, peel of heavy tape and on it sticks until you feel like removing it. That's why everyone loves Autokits. Install yourself even if you're a noob, and it looks great. It also utilizes a few clips that are on the bottom or your bumper. Very simple.
Old Nov 30, 2011 | 12:41 AM
Soliditude's Avatar
Soliditude
Thanks
The kind you'd get at any department store. I get mine at Wal-Mart or AutoZone. It's gray-colored tape with a red outlining that you feel. That's the kind that comes on the diffuser from Autokits as well.
