Warranty almost out-What to look hard at?
Old Nov 14, 2011 | 12:58 PM
MPdesign's Avatar
MPdesign
Thumbs up Warranty almost out-What to look hard at?
My warranty is running out soon.
What parts of the car should I look hard at to get them replaced/checked before warranty runs out 6yr 60k miles.
Here is pic, because.. hey why not!
(no - that is not me, not my car, not my babes)
Old Nov 14, 2011 | 01:13 PM
bythabay's Avatar
bythabay
20 Year Member
the spark plug tube seals are a personal favorite of mine to check
Old Nov 15, 2011 | 04:32 PM
MPdesign's Avatar
MPdesign
Thanks bythabay!
Anyone else have recommendations?
Old Nov 16, 2011 | 10:20 PM
NCHIINFMNGR's Avatar
NCHIINFMNGR
What year, lloks like an 07 and it is 4 yr/60k 6yr 70k p-train
Old Nov 16, 2011 | 11:07 PM
MPdesign's Avatar
MPdesign
That is not my car. Mine is 2008 G37 closing in on 60,000 miles.
Old Nov 17, 2011 | 10:36 AM
NCHIINFMNGR
Make sure judder kit is done, upper cooling hose dosent leak, upper lid on
guage cluster peels up, steering wheel material peels, make sure drivers seat bottom does not have a bubble in it and leater is distorting, rear muffler rattels on start up, while scrolling thru stations at times will bounce around, make sure wheel bearings are ok, and if a man, make sure trans feels ok and no abnormal noises, rattle tsb by front windshiled, but that is about it, any q's let me know
Old Nov 17, 2011 | 10:55 AM
MPdesign's Avatar
MPdesign
NCHIINFMNGR,
What is:
"rattle tsb by front windshield"
I really appreciate your expertise. This is very much needed.
Old Nov 17, 2011 | 12:12 PM
NCHIINFMNGR
Check here on the forums, there is a tsb for a rattle noise by windhield
where they take off the cowel and insulate it so it does not creek against the windshield
Old Nov 17, 2011 | 02:13 PM
bluecoupe's Avatar
bluecoupe
Axle bolt TSB if you hear a "tink" sound when going from forward/reverse
Old Nov 17, 2011 | 04:14 PM
audtatious's Avatar
audtatious
NCHIINFMNGR,
What is:
He may be referring to the following:
http://www.infinitig37.com/TSB/1RW10.pdf
Old Nov 17, 2011 | 08:33 PM
NCHIINFMNGR
Not that tsb, i dont know the number off my head, at home not work anymore, but this one requires to remove the wiper arms, remove plastic cowel and insulate the underside of the plastic so it does not "creek or tick"
i see this all the time, not so much the backflush for noise, maybee a handfull,
Old Nov 17, 2011 | 11:22 PM
audtatious's Avatar
audtatious
I know there is the cowl noise but I don't believe there is a specific TSB for it. If there is I don't seem to have it.
Old Nov 18, 2011 | 12:41 AM
singledark's Avatar
singledark
not bad source.
Old Nov 18, 2011 | 10:12 AM
NCHIINFMNGR
the itb is itb02-028a, it is for the older g modles, but numerous customers come in and complain about this same noise and this solves the problem on the newer ones!!
oldies but goodies still
Old Nov 18, 2011 | 04:07 PM
soolman32's Avatar
soolman32
Look at the steering wheel and instrument cluster cover. If you have peeling or scratches on the wheel and/or your cluster cover is no longer sits flush, those are two items you can get replaced under warranty. those are the only items I've had issues with and got replaced.
