Exhaust alignment
Old Oct 29, 2011 | 02:26 PM
sriniG37's Avatar
sriniG37
Exhaust alignment
i noticed this on my G a month back... the left exhaust tip is lower than the right side (see pic)... i showed this to my dealer and he said that they needed to take a closer look.
have any of you seen or had a similar problem before? the dealer said that there was some rusting/damage hope its not serious... are things like this covered under warranty?
Attached Thumbnails Exhaust alignment-268109_10150258537164788_545429787_7309038_2674759_n.jpg
Old Oct 29, 2011 | 02:34 PM
breftayka's Avatar
breftayka
There are a lot of threads on this topic. It is a design flaw. Most have the same problem as you. I think I remember a few people saying the dealer replaced their exhaust, but came out with the same result.
Old Oct 29, 2011 | 02:44 PM
j23a45m's Avatar
j23a45m
doesn't affect performance, just a eye sore once you notice.
Old Oct 29, 2011 | 02:47 PM
Unique Bliss's Avatar
Unique Bliss
Correct sir. I had mine replaced for the "exhaust rattle" that a bunch of people have experienced. After, my exhaust is a bit lower on the right side... No biggy.
sriniG37's Avatar
sriniG37
oh... i tried searching before posting but could not find anything... not searching enough probably :P thanks for the reply...
Old Oct 29, 2011 | 03:21 PM
stickboy's Avatar
stickboy
I had the same issue and finally took it to the dealer a week ago and had them look at it. The dealership had already replaced my exhaust once due to the infamous rattle issue and was not going to replace it a 3rd time simply due to a design flaw. They put the car on the lift and bent one of the exhaust mounts (with my permission) and it fixed the issue.
Old Oct 29, 2011 | 03:33 PM
JSolo's Avatar
JSolo
Just say no!!!!!
I was going to say, isn't this something that can easily be adjusted by bending the offending tip. On my old camaro, the tips were secured with a sort of clamp - loosen clamp, readjust, tighten, done deal. Not sure if this is applicable to the G however.
Old Oct 29, 2011 | 05:26 PM
OB G's Avatar
OB G
There's books where the exhaust hangs in the frame. You can bend them like the earlier post. Easy fix. Or just get a new exhaust
j50ny
Jul 21, 2017 10:46 AM
Dillybar12
Engine, Intake and Exhaust
Sep 14, 2015 12:54 PM
infinitiandb...
Intake and Exhaust
Sep 11, 2015 08:26 AM
jfisher
Sep 9, 2015 04:17 PM
