cruise control problem
Old Jun 25, 2011 | 02:36 AM
j37hasag37's Avatar
j37hasag37
Has anyone had this problem before? Where you hit the on/off button and the cruise indicator doesnt come on?
Any input?
Old Jun 25, 2011 | 11:34 AM
LilRocket's Avatar
LilRocket
Any input?
I haven't used it at all. I'll try it later on today
Old Jun 25, 2011 | 10:23 PM
Shadow G37s's Avatar
Shadow G37s
Could be a slew of things, but mine did this early on, and it was related to the pedal position. You have a sensor on both your clutch (if applicable) and brake pedals that works like a stoplight switch; when you depress either pedal, the sensor cuts off cruise, and similarly won't let you engage cruise when a sensor is tripped. I noticed that if I used my toe to pull upwards on the brake pedal it would allow me to set cruise, so I used a E clip on the sensor to space it a little higher. You could also probably adjust the sensor downward (or just let infiniti solve it!). Hope that helps!
eljoker
Future Models
19
May 30, 2022 11:48 AM
TheLocNar
Dec 22, 2015 07:52 PM
Raleclair
Oct 8, 2015 02:06 PM
Cmedlin96
Sep 20, 2015 11:09 PM
m3clubracer
Sep 20, 2015 09:20 PM
