09 G37: Stillen Gen 3 Cold Air Intake + Grounding Kit installed (+ dynos!!)
Old Feb 26, 2011 | 01:07 AM
borfoo3's Avatar
borfoo3
Hey guys
This is my attempt at making my first post a useful one so let's get down to business:
1- Stillen Gen 3 Cold air intake:
Pros: awesome gains across the band, sexy growl, imo: best (reasonably priced) $/hp upgrade for the G37
Cons: A real Pain to install if doing it urself... otherwise, nothing else
2- Stillen Grounding kit:
I would like to talk a bit more about this upgrade since I previously owned a 2008 (5-spd) G37 before my current 2009 (7-speed) G37 and one of the things I disliked was the lag in shift time response. Of course, I'm not expecting GT-R spec shift times, but there was a noticeable lag which was more like a hesitance as the car tries to select the 'optimal' gear.
In short: the ground kit basically made it feel like a new car to me.
No more 'wait for the car to make up it's mind' moments as my foot steps down on the aluminum gas pedal..
No more 'hit the paddle shifts ~500rpm earlier in anticipation for the upcoming gear upshift..
so for those of you who share my problem, I highly recommend the ground kit solution!
Stillen Ground Kit:
Stillen Gen 3 Cold-Air Intake:
installed:
Base Dyno:
Dyno after intake + ground kit (everything else is stock):
Comparison: stock vs. intake:
Air- fuel ratio after install:
Old Feb 26, 2011 | 01:26 AM
Steveo47's Avatar
Steveo47
nice gains! why did you go with a stillen grounding kit and not a Black Betty Kit?
Old Feb 26, 2011 | 01:32 AM
P Casey's Avatar
P Casey
awesome info. I just installed mine today. I was expecting to have a lot of trub but it was pretty easy
Old Feb 26, 2011 | 01:33 AM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
wow those are great gains what gear did u dyno in
Old Feb 26, 2011 | 01:41 AM
P Casey's Avatar
P Casey
at what rpm r u all hearing it growl?
Old Feb 26, 2011 | 01:56 AM
Obvis07's Avatar
Obvis07
very nice gains. i never knew that intake gave u that much HP or a grounding would help ur performance
Old Feb 26, 2011 | 01:59 AM
TVPostSound's Avatar
TVPostSound
Very lean AFR above 6500.
Any detonation??
Old Feb 26, 2011 | 05:16 AM
borfoo3's Avatar
borfoo3
replying to some of your questions:
1- Honestly, I don't think there's much of a difference in choosing stillen vs black betty grounding kits since both kits seem to be very good at what they do. In my case, i just saved a bit on shipping since i was ordering the intakes from stillen at the same time..
2- I believe it was dyno'd at 5th gear
3- growling was most enjoyable in 3-4k rpm @ WOT.. nothing that would wake up the neighborhood though..
4- intake gave the hp's.. grounding smoothed the transition from engine to tarmac
5- I think I'm still within good limits (as far as the dyno guy said) in terms of A/F ratio..
no detonation as far as I can tell.
Update: Just did a 420 mile trip today from AZ to CA with a heavy rainstorm in CA.. All systems green so far, and the intakes seem to be handling the rain quite well. Hope it stays that way!
Old Feb 26, 2011 | 10:25 AM
2008G-Man's Avatar
2008G-Man
Did you need to make any ECU programming?
Old Feb 26, 2011 | 10:29 AM
SterlingDriver's Avatar
SterlingDriver
Very nice gains for so little cost...
Old Feb 26, 2011 | 11:26 AM
TVPostSound
Please invest in a tune, you're running over 15:1 at top RPMs.
Old Feb 26, 2011 | 12:02 PM
cvt's Avatar
cvt
His afr is at 12.5 below 3500 and is dancing on 12 from 5500 and on. i think he's fine. a tune would just polish it up.
...still 29.6 hp from an intake is really hard to swallow. the median gains from the stillen are from 12-18 from G37s and 370s...of course it doesn't reallay matter what the number is, he has his delta and gains across the curve. i guess that's what really counts. congrats
Old Feb 26, 2011 | 12:32 PM
wlmngtn's Avatar
wlmngtn
lol grounding kit = placebo effect
Old Feb 26, 2011 | 12:34 PM
wlmngtn's Avatar
wlmngtn
Really nice gains btw, as soon as my Stillen intake is powder coated, I am getting in installed.
Old Feb 26, 2011 | 02:11 PM
Chi-City-G's Avatar
Chi-City-G
Just a quick question: how come it says under the customer line item on the dyno, 08 G37 for the base and the 09 G35 for the intakes? Is this just a weird error entered or was the base on your 08?
Just noticed that and wondered... Awesome gains though!
