Coupe performance - how much does it really matter to you?
Old Jun 7, 2010 | 08:27 AM
  #91
BOXER83's Avatar
BOXER83
I would not be buying this car with that HP. We would be like a Honda then. I really think it should have more.
  #92
BOXER83's Avatar
BOXER83
Nissan/ Infiniti should change the compression ration and go with FI.
Old Jun 7, 2010 | 09:25 AM
  #93
Mike's Avatar
Mike
Lowering compression would lessen throttle response. The N54 uses high compression, which is partially why it feels so responsive.
Honestly, I would miss the power less than the extra 3-4k I'd save on a G25. SOB now it has me seriously thinking if I should wait on buying a TDI.
Old Jun 7, 2010 | 09:40 AM
  #94
BOXER83's Avatar
BOXER83
I plan on going FI so I think it won't matter. I like the ration in the fact that you don't need so much boost to produce allot of HP. 12psi and GT28 .88 get you 600+. Our car is compatable with all the FI cars out there.... BMW 335i
Old Jun 7, 2010 | 11:56 AM
  #95
dsindm's Avatar
dsindm
I bought the car more for design, comfort and handling than for pure power. I do want fairly quick acceleration for idiot avoidance on the highway, but I've had that in cars with less hp than we have.
I would expect to pay a little less but yes, I would still have been very interested in the car with less muscle.
Old Jun 7, 2010 | 12:43 PM
  #96
BOXER83's Avatar
BOXER83
I think I would have also. The car is just plan beautiful.
Old Jun 7, 2010 | 02:49 PM
  #97
dainjarouz's Avatar
dainjarouz
how bout just switching to direct injection, Infiniti? easy horsepower and no lost mpg.
Old Jun 7, 2010 | 03:23 PM
  #98
MSCA's Avatar
MSCA
Yeah, the only problem with direct injection is that everyone seems to be having serious carbon build-up issues once the engines get some miles on them. Just look at how bad of a problem Audi is having....
The fact that the VQ isn't direct injection is one of the major reasons I'm going with the Infiniti in the first place!
Old Jun 7, 2010 | 05:30 PM
  #99
JohnEnglish's Avatar
JohnEnglish
The problem is that in non-DI engines the fuel spray "washes" thew valves and prevents carbon build up. In DI engines this doesn't happen.
I've read that some manufacturers are experimenting with adding "secondary fuel injectors" whose sole purpose is to spray the intake vales with a bit of fuel every so often to prevent carbon build up.
Old Jun 7, 2010 | 05:59 PM
  #100
MSCA's Avatar
MSCA
Yeah, I know...I've followed the whole direct injection debacle for quite some time now. Adding another injector to "wash" the intake valve seems silly because there would have to be one injector added per cylinder....and that would be in addition to the direct injection injectors already in the engine. Seems like adding port injectors would defeat the purpose of direct injection, unless they were used on a very light duty cycle or only when PCV or EGR gases are flowing into the combustion chamber.
I think the solution will involve a way to re-engineer the way PCV and EGR is routed back into the combustion chamber. Either way, it's a serious problem and there seems to be no easy way to solve it right now. I'm just glad Nissan hasn't gone DI with the VQ engine.
Old Jun 7, 2010 | 06:16 PM
  #101
JohnEnglish
I've seen some of the pictures at vwvortex.com and it's insane. Cars with 80K on them look like they have 40 year old engines.
From what I've read about the "secondary injectors is that they would probably be located higher up in the intake manifold so you would only nee one or two per bank of cylinders and they're light duty only firing some of the time. However, that all seems to add unnecessary complication. You're probably right with the EGR/PCV solution.
The new VK V8 in the M56 and QX56 has DI so I imagine it'll eventually come to the VQ.
Old Jun 7, 2010 | 06:53 PM
  #102
dainjarouz's Avatar
dainjarouz
without losing the audience with technical jargon could either of you guys explain how DI leads to carbon buildup? TIA
Old Jun 7, 2010 | 06:56 PM
  #103
MSCA's Avatar
MSCA
Cliff's Notes version: Port fuel injectors spray fuel past the intake valve, effectively cleaning it as it goes. Direct injection injectors spray fuel directly into the combustion chamber, thus "skipping" the intake valve. Over time, carbon deposits build up on the intake valve because the fuel is not passing over it (and cleaning it) on direct injection engines.
Old Jun 7, 2010 | 07:43 PM
  #104
Jamler's Avatar
Jamler
Well Stated MSCA!
Old Jun 7, 2010 | 08:08 PM
  #105
911turbo's Avatar
911turbo
G = needs more power lol
