Is this normal?
Old Nov 25, 2009 | 09:36 PM
G Nack 37s's Avatar
G Nack 37s
Is this normal?
I have my traction control off, revving the car to about 4k rpm and dump my clutch, it feels like the gas petal is being step on by itself and the car feels like it doesn't want to go. feels like like its being redline but it is only around 3k-4k. Even when I'm changing from 1st to 2nd. Just very loud revving.
Old Nov 26, 2009 | 02:29 AM
Weiboy718's Avatar
Weiboy718
sounds like your clutch might be shot lol!
Old Nov 27, 2009 | 11:15 AM
Callaway's Avatar
Callaway
Arm flailing tube man
Do you do this regularly?
Old Nov 27, 2009 | 11:16 AM
sbmwg37s's Avatar
sbmwg37s
Yeah sounds like your clutch......good luck
Old Nov 27, 2009 | 11:22 AM
BocaIvan's Avatar
BocaIvan
I think it's time for a new clutch.
Old Nov 27, 2009 | 12:41 PM
TomieG's Avatar
TomieG
Is you clutch catching? cause if not then its frying your clutch. Try feathering it until it catches then drop it and pop it.
Old Nov 27, 2009 | 01:08 PM
Namir's Avatar
Namir
"Is this normal?"
I think a better question is why the hell are you dumping your clutch from 4k revs?
On a stock clutch you shouldn't be "dumping" the clutch, and definitely not from 4k.
Old Nov 27, 2009 | 01:12 PM
Mike's Avatar
Mike
clutch or VDC.
You need to adjust your driving unless you want some expensive repairs down the road.
Old Nov 27, 2009 | 01:48 PM
DmfG37sTT's Avatar
DmfG37sTT
From my exsperiance our transmissions our like glass...Ive herd from several shop owners that our cars can handle alot of power but under real pressure will break in a heartbeat......If your car is more along the line of a track/race car to you I would suggest not just a new clutch/flywheel but a whole new tranny/ or a built transmission. The transmission is prolly the one and only thing I hate about our cars in the fact that they break under any kind of pressure....from my exsperiance
Old Nov 28, 2009 | 12:46 AM
G Nack 37s's Avatar
G Nack 37s
i did it once about a week ago and it just happen with vdc off. other than that the clutch grabs just fine when down shifting and so forth. Its weird cause i revv at about 4k in my old 94 integ and it never happens.
Old Nov 28, 2009 | 01:01 AM
Weiboy718's Avatar
Weiboy718
try to do a ecu reset and see how that goes. if it grabs on down shift then your clutch should be fine
Old Nov 28, 2009 | 01:09 AM
G Nack 37s's Avatar
G Nack 37s
Would it be fine if I reset it just unplugging my battery terminal?
Old Nov 28, 2009 | 01:59 AM
heff's Avatar
heff
ur G isnt a honda lol
Old Nov 28, 2009 | 02:03 AM
G Nack 37s's Avatar
G Nack 37s
point exactly, it shouldn't be happening to a G if I can do it to a honda.
Old Nov 28, 2009 | 09:47 AM
Namir's Avatar
Namir
I might be wrong but I doubt your old honda had 270 lb-ft of torque...
And you don't have to dump the clutch from 4k to get a fast start. With a rear wheel drive car and VDC off you'll most likely just spin the tires anyway, its going to be faster to feather till it grabs then dump it.
