frustrated with the G
Old Aug 9, 2009 | 11:41 AM
nestle_!9's Avatar
nestle_!9
GRRR!!! !#$^%$# ,,, my car wont start for the 2nd time for this month alone!! needed a jumpstart from my DAD's civic which doesnt FAIL him at all!! And our cars are considered luxury?!!!! anyway ,, will call the dealership ,, see what they think ?
bad battery maybe?!
Old Aug 9, 2009 | 03:17 PM
DrJones's Avatar
DrJones
If this is the second time... did you check your battery connections just to make sure they are tight... perhaps one terminal may be loose.
Old Aug 9, 2009 | 03:34 PM
CEELOSG37S's Avatar
CEELOSG37S
LA G Club
Tight is always right.
Old Aug 9, 2009 | 04:09 PM
G37Sam's Avatar
G37Sam
Your sig shows you got neo chrome business going on (electronics).. could they be the source?
Old Aug 9, 2009 | 04:17 PM
CEELOSG37S's Avatar
CEELOSG37S
LA G Club
Not electronics. They are lug nuts. KICS Neo Chrome R40 lugs.
Old Aug 9, 2009 | 04:19 PM
G37Sam's Avatar
G37Sam
oh excuse my noobness then
Old Aug 9, 2009 | 04:22 PM
CEELOSG37S's Avatar
CEELOSG37S
LA G Club
Its all good sam.
Old Aug 9, 2009 | 04:23 PM
WhosUrBuddiee's Avatar
WhosUrBuddiee
Yes Sam, his lug nuts are causing his car to not start.
Old Aug 9, 2009 | 04:45 PM
aznutx's Avatar
aznutx
check the dead battery threads, chances are it's just the battery
Old Aug 9, 2009 | 05:29 PM
DrJones's Avatar
DrJones
Nestle what was the first diagnosis when you took it to the dealershop?
Old Aug 9, 2009 | 05:34 PM
WhosUrBuddiee
Most likely loose battery terminal. New Camaros had the same issue.
Old Aug 9, 2009 | 05:47 PM
bschurr's Avatar
bschurr
Any recent electrical work?
If it is not a loose battery terminal or faulty battery, I would suspect a loose ground or similar voltage fault causing a drain. Another possibility would be the alternator.
How long in between your last dead battery situation? and, how long did the car sit before you last drove it?
Old Aug 9, 2009 | 05:53 PM
WhosUrBuddiee
May sound dumb, did you leave the light on in the car?
Old Aug 9, 2009 | 07:38 PM
G4me's Avatar
G4me
Ummm.. only a front right lug nut can cause a starting problem. Something to do with the harmonic vibration causing the terminals to loosen.
Common knowledge.
Old Aug 9, 2009 | 08:50 PM
solopresident's Avatar
solopresident
our batteries are ****
